Where to mount Antenna
Discussion in 'Communication (CB | GPS | HAM)' started by 4X4HIGH, Nov 7, 2002.
  1. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Like the subject line says, where is the best place to mount a Wilson 5000 trucker Antenna on a 89 blazer? I have been to the Wilson web-site and I find it hard to really understand where the best place would be. It says the coil should be above the roof line but also that the roof is too big a ground plane. My blazer has a 6" lift with 35's and I don't really want to be hitting everything in sight by mounting it too high. Would it be ok to mount it off the passenger side body near the top rear corner?
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Best place to mount it would be the roof of the cab, but I hear /forums/images/graemlins/ears.gif your concerns. You should be able to mount it about anywhere you want. Just try it and see how it works. I run a 102" Stainless Steel whip on a spring mounted to the overhead light bar. Works pretty good for me, but it does wack tree limbs alot. /forums/images/graemlins/k5.gif
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used to have mine on the roof but I kept stripping it off. I ended up going to a ball mount on the side all the way in the rear as high as I could put it. I then put a 5' firestick on a spring mount. It has stayed better in that location.
  4. '72brett
    '72brett 1/2 ton status
    Dec 3, 2002
    166
    northwest Iowa
    I run a '72 blazer with the fiberglass top. that really cut my options. What I did was make my own bracket out of a thin sheet of steel and sandwitched it between my bed and the top, help sceurly inside with a bolt. It is mounted in the very back on the driver's side with a 5' firestik II antenna. With the fiberglass, you dont have to worry about the ground plane, and also the coil on the firestiks isnt at the base, it goes all the way up. I think that is the best mount I have seen around here. I may also be a little impartial though too. /forums/images/graemlins/k5.gif
  5. 4GUNZ4X4Z
    4GUNZ4X4Z 1/2 ton status
    Aug 10, 2000
    3,459
    Mustang, Oklahoma
    Go to the firestik web site should have plenty of info.
  6. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    I was up in the mountains last week and saw a Taco truck with the antenna mounted between the hood and the front driverside corner panel.
    It looked pretty good and out of the way /forums/images/graemlins/thumb.gif
    Anyone tell me how they did it or why this wouldn't work? /forums/images/graemlins/ears.gif
  7. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    A lot of people mount the antenna like what you mentioned... they use a mount like this.
    They can be found at some truckstops and cb shops. If all else fails I found them at Tower Electronics
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I used to have mine mounted on the mirrors also. It worked out pretty well.
  9. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Where can I get one of those brackets? /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  10. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think Radio Shack or a decent truck stop would have them.
  11. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    Thanks!
    I was thinking about my mirror too but mine are kinda jacked right now and I may have to change them out soon. /forums/images/graemlins/crazy.gif
  12. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    The roof should be the best place fo that Wilson, But like you said it will hit just about every thing and if you wheel in the trees it will hit alot more stuff.
    If you go the side I would think you would have to go with a Ball mount, And do like Sandman and mount it up as high on the body as you can.
    Somebody put a ball mount low on my 83, And after three hrs at the CB shop and trying all the Antennas they had we couldn't the SWR's down past 2. The only thing they could think of was it was mounted to low on the body and I getting to much interferance (sp)
    Eric
