Where to mount cb??????
Discussion in 'The Garage' started by freeflow, Sep 13, 2006.
  1. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    Well i just got all my cb stuff today- dual 4' firestik's and a cobra 29wxnwst. Im starting to hook it all up, got the antenna's mounted up right behind the cab, but i cant decide/ find a good place to mount up the cb:confused:
    Where do you all have your cb's mounted???? pics would be great.
    Thanks brad
  2. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    My buddy had it under his seat with the dials visible if he looked to his right and down. It really worked pretty well. I am going to put mine in my tuffy console. What kind should I get and why?
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. Cornfield creations
    Cornfield creations 1/2 ton status
    Oct 19, 2005
    1,283
    Jasper, Indiana
    I always mounted mine right underneath the fold down ashtray on the dashboard. I took out the two screws the mounted the ashtray to the dashboard at the bottom of the painted area, and I bolted up the bracket using those bolts. Looks nice and clean. Its almost like chevy knew something would be mounted there. Even if you keep your ashtray down it looks good. Access to wiring is nice too.
  5. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Berry nice!!! [​IMG][​IMG]
    I had forgotten about it and yer headliner!!!
  6. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    My junk, again..................
  7. tenderfoot1877
    tenderfoot1877 Registered Member
    Apr 10, 2005
    13
    San Antonio
    CB mount
    I mounted my CB directly under the stereo. I have exactly the same set up as you and it is very convenient under the dash.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    hands down, the BEST spot for it, short of mounting it into the dash pad just above the ashtray. IIRC a 29 has the mic connector on the side, like my PC66 does. this wont like being flush mounted like that very well.
    i tried that. kept getting my mic cord wrapped around my foot, hitting my knee, and wrapping the mic around the accelerator pedal. :doah:
  9. freeflow
    Nov 6, 2004
    274
    I was looking at mounting it by the ash tray but it would almost be rubbing on the 4x shifter and i like resting my foot in front of the 4x shifter when its along drive.
    I like the look of it mounted to the roof above the rear view. Im thinking about making a small box to mount to the roof and then mount the cb, and a few swithces to it. And either cutting down or replacing the stock sun visors
  10. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    Prolly easier for those of us with earlier model shifters, or doublers with the sticks pushed back... I betcha with a '208 style shifter you'd be in trouble more... but here's my junk.
    Though I hafta admit, I kinda like what Dontoe's done. It's tough to hang crap in a full-convert and do it well ... but dang, running wires around the roll cage, blah. Still, :thinking: ... :)
    http://www.slosh.com/dremu/dark-side-calls-me.JPG
    -- A
  11. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Here how mine is mounted. It is in the factory stereo slot. I still need to fab a cover plate for it to smooth things out:D .
    CB is a PC79elite. I have had no issues with the mic cord and my feet with this mounting.
    Ira
  12. SC-Texas
    SC-Texas Registered Member
    Apr 11, 2006
    83
    Houston, TX
    I am planning on adding a CB ro my rig also.
    I would like to mount it in the center console or in the dash somewhere.
  13. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
  14. SC-Texas
    Apr 11, 2006
    83
    Houston, TX
    did you have to modify anything in teh dash to fit the radio in?
  15. readymix
    May 30, 2004
    6,706
    26
    Cut away about 6 square inches on the right side of the vent hole.
  16. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    its sideways i know. my cb is on a shelf (i think the shelf was a factory option? it matches the headliner perfect and everything, i duno) i like it where it is, its out of the way, and i can store stuff on the shelf as well:D
    edit* you cant see it as well as i thought:doah:
  17. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  18. diesel4me
    Jul 24, 2003
    17,561
    940
    Massachussetts
    just like my truck had it!..
    My 74 K20 had a realistic CB mounted there,where an A/C duct would have been,if it had A/C...no cutting required,it fit perfect!...the newer "Uniden" mini CB's will just fit in that factory hole too!..I found it a very convenient spot for my CB,and I just put the hot wire to the one for the cigg lighter!..
    ..I had a scanner under the ash tray,so it wouldn't have fit there,and I'm 6'4" tall,so a ceiling mounted CB would have given me a headache,litterally!..--that spot is perfect for a stereo too..GM should have put them there factory--at least you can SEE it without taking your eyes off the road!....:crazy:
  19. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Like on the newer pickups...
    That's where they always put aftermarket head units and it works out great.
    I went out and took some shots of my recent install, hopefully it helps, I haven't seen too many guys mount it here.
    It clears the TC shifter even in 4wd and it swivels so if I hit it w/ the seat or something it doesn't break off. I went and got a strip of metal and bent it in the vice, then drilled holes in it and cut off the extra. Then screwed it into the transmission tunnel w/ two screws then bolted the cb in place. I also ran the wires under the seat and then under the carpet to the front to keep it clean and safe.
    Tell me what you all think.
    -Avery
  20. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    Thats an "interesting" dash cover :eek1: but i do like the C/B mount I'm assuming you don't have many middle seat passengers
