Where to mount Tach
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Haulgas, Sep 8, 2001.
  1. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    Where are you mounting your tach ? I have a 87 and don't want to mount it on the dash. Any suggestions?
    IT'S NOT JUST A J**P THING AND I DO UNDERSTAND
  2. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I don't have one, but i think I have seen them mounted to the steering column, if you don't want it on your dash..
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear,(sitting next to truck) 12 bolt (still in truck) dana 44 front, TIRED ol 305----
  3. Haulgas
    Mar 25, 2001
    208
    Phoenix Az
    I have a auto so when you change gears the tach would move
    or the key switch is in the way.
  4. Grim-Reaper
    7,385
    Atlanta
    It's not a problem if you have a small tach. I have Tilt and a Auto and it's worked out fine. Only thing you can't see when in Drive is the gear indicator. I mounted mine foward so it's not on the collar that rotates with the shifter.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My 87 's is also on the column no problems.
  6. i_4x4
    i_4x4 1/2 ton status
    Feb 20, 2000
    359
    Brighton, Colorado. USA
    MIne is also on the column. w/ auto. The only thing that is obsturcted is the p-brake light. It is mounted at 1 o'clock when it is in park, and about 2 o'clock when in drive. The tack is turned so when it is in Drive it reads normal, &amp; when in park it is turned slightly to the left. Also it is 3" or 3.5" Sun tack. I like it.
    Later ED
    Get use to the view.
    Because, if your not the LEAD DOG the view never changes.
  7. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    I have mine mounted to the cab post (it's actually screwed into the trim) just about 1" off the dash. It doesn't impede my view either.
  8. FILDO
    FILDO Registered Member
    Jul 23, 2001
    7
    My 5" Monster Tach sits underneath the center of the dash on the floorboard right next to the transfer case shifter. I'm not one to look at the tach while I'm tearing up the dunes so it doesnt really matter. I just listen to the motor. Phil
    PS.Email me if you want to see a pic. Aaron37977@aol.com
  9. CV202
    CV202 1/2 ton status
    Nov 14, 2000
    454
    Kingfield, ME
    Mines mounted on the column with a big hose clamp. I've got it leaning off to the left so I can still see all the guages and idiot lights. Mines a standard, so I don't have the shifter problem. Works great with no problems.
    Why do people keep calling it a Bronco!!!!! [​IMG]
  10. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Here's how mine is on the column. It blocks the gauges a little, but its not meant to speed either.
    http://wsphotofews.excite.com/027/3r/UZ/QB/5962747.jpg
    <a target="_blank" href=http://wsphotofews.excite.com/035/rp/gJ/GO/Sn54030.jpg>http://wsphotofews.excite.com/035/rp/gJ/GO/Sn54030.jpg</a>
    Rob 85K5
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  11. baldbandit
    baldbandit 1/2 ton status
    Jun 16, 2000
    282
    Marshall TX
    mine is mounted about half way up the window pillar. I like it better than on the column.
    baldbandit
    "Have you driven over a F@RD lately!!
  12. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I've seen tachs screwed to the middle of the dashboard.. but it kinda gets in your way. I think that's where my tach is going when I put it in though. Even though I took the shifting capabilities out of my column.. I'd never see it anyplace below the dash. I never really look at my speedo anymore either. listening to the engine and shifting with my megashifter help me know what speed I'm at.
    <a target="_blank" href=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</a>
    ".. Sanatarium.. leave me be..."
  13. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    I put one in the ash tray
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  14. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i have mine on the window pillar, with a 1 inch wide band of stainless around it that is screwed through the trim, it's sweet, but run the wires neatly
    Tork DSR
    I just got a winch, it takes the fun out of things.
