Where to pick up 400 crank?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fortcollinsram, Dec 9, 2001.
  1. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Does anybody know where I can pick up a 400 crank for the 1-piece rear main seal for a decent price... I wanna build stroker motor similar to the GM HT383 crate motor...thanks for any help...
    <font color=red>1987 Blazer K5, 4" Rancho Lift, 33" BFG AT, Dual Battery setup, AND MORE TO COME [​IMG]
    Was that a speed bump? No, just a Rice Rocket </font color=red>
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Speed-o-Matic has adds in Car (Chevy) Craft and Hot Rod. They sell everything you need for stroker motors. semi-pricey. Might try junk yards, 400's are getting rare.
    -zakk
    '77 1-Ton K5
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  3. pr1aw
    pr1aw 1/2 ton status
    Sep 17, 2000
    144
    San Diego CA
    PAW SELLS THE PISTONS, RODS, BEARINGS AND CRANK FOR $659. 383 STROKER
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Guys, he wants a 3.75" crank for <font color=orange>1 piece rear seal (86 and later)</font color=orange>
    You can get cranks made with the 2.45" main journals from companies like Scat or Eagle. Check with them to see about one of these for 1 piece rear seal. You might also check with Summit and on eBay.
  5. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    <a target="_blank" href=http://www.speedomotive.com>Speed-O-Motive</a> ~~ the stroker experts since 1946~~ Has a one piece rear seal 383 kit for $605
    in the latest issue of Chevy Hi-performace ad says FREE SHIPPING!
    <font color=red>Life is like a mud hole:</font color=red><font color=blue>
    When the S#!T gets deep, you have to keep moving and friends can always pull you out</font color=blue>
    55 Willy's
  6. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Okay time to gimme an estimate on HP and torque...If I got that speed-o-motive kit forged "stroker" kit, upgraded to the TRW forged flat-top pistons, swapped to Vortec heads(and home port and polish), GM performance intake to use TBI and Vortec heads, a realatively mild Comp hydraulic roller cam, Comp hydraulioc lifters, and Comp roller rockers... On top of that, I would ditch the belt driven fan in favor of a dual electic setup, go to a true-roller timing chain such as the Edelbrock unit, and top it off with a TBI spacer and K&amp;N 14" round air cleaner...
    That being said, what kinda numbers do you 'think' the engine would put out?
    Chris
  7. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    all that and you want the stock TBI to function???
    With the "forged" stroker kit you are looking at 10.2 to 1 and with the flat tops you step up to 10.9 to 1.
    The stock TBI was ment for a 210 horse 9.3 to 1 350
    Your picking up 40 horse just with the Vortecs
    And with the cam and induction upgrades I would saw you'll be upward to 375 to 400 ponies.
    55 Willy's
  8. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What would I have to do to the TBI in order for it to work? Also what is the combustion chamber size on the Vortec heads? How can I keep the CR down a little bit closer to stock? Thanks
    Chris
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Whatever you do, don't buy some cast or forged in China garbage. Get something of quality and avoid problems down the road. Believe me, a CRANKSHAFT is very important to your continued travel down the road, and skimping here could be costly. Very costly.
    Tim
  10. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Check out the December issue of Petersens 4W&amp;OR. it has an article on TBI build ups.
    55 Willy's
  11. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    I picked up a NEW 400 crank on eBay from a speed dealer for $139. It is a two piece seal though. Sure beats $605 from whoever that was on the above post!!
    ken
  12. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Those $600+ kits come with a complete rotating assembly. New crank, new pistons, recon connecting rods, bearings, etc. You get way more than just the crank for that price. [​IMG]
