Where to put oil filter Re-locator?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by muddbogg89, Mar 31, 2003.
  1. muddbogg89
    muddbogg89 Registered Member
    Mar 19, 2002
    97
    Chicago(suburbs)
    I gotta do an oil filter relocation because of clearance issues with these damn headers.I got a TD performance kit from summit, it comes with 30in hoses.
    If i put it on the inner fender it would be facing upward making for a real messy oil change right? Or would the oil drain from the filter back into the pan, and end up taking longer to circulate on start up?
    Or should I just put it on the frame?
    /forums/images/graemlins/k5.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    if i was to do it i would put it on the frame horizontally. that was you wont catck it on a rock or something. i like it below the truck so when i pull the drain plug i can pull the filter off also. just my .02
