Where to put oxygen sensor on headers?
Discussion in 'The Garage' started by bigburban383, Dec 31, 2003.
  1. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Should I put it on the collector on the driverside? I dont want to just put it on #7's tube cause it'll screw up the flow. Anybody done this before?
    Thanks /forums/images/graemlins/thumb.gif
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    as far as i have ever heard they are supposed to be located after the burn off area of the exhaust, but ive seen stock ones closer to engine than that, so hmm
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    it needs to go into the collector. If you are running full length headers then you are most likely going to need a heated 02 sensor
  4. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Oh that sucks, heated sensors cost a lot from what I remember.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    $55 for a Bosch one at Autozone--I"m sure someone has an AC Delco one for $70 or so. I wouldn't use a Bosch.
  6. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I looked at my dad 90 and his stock o2 sensor is right at he y pipe. so mine on my wagon is going on the driver or passenger side collector.
  7. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Whoa wait! Your dads truck runs fine with the sensor where? All the way back at the Y pipe? That must be custom cause my 90 has it right on the manifold close to the engine. If it works GREAT!
  8. dyeager535
    26,980
    Really need to get a scanner on it after install, to see if it's within the proper ranges. Experiences vary when using an un-heated O2 sensor back at the collectors...some see the vehicle dropping out of closed loop at idl (O2 sensor cools off) and some don't.
    Only way to know for sure is to watch it after install with a scanner.
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Does the sensor go into the heder itself or the exahust pipe right after the collector?
  10. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    i've got mine down on the collector. i haven't had any problems yet. and it's just the stock O2 sensor also.
  11. bigburban383
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Well, im not going to spend any money and try it on the collector. Thanks for the help /forums/images/graemlins/thumb.gif
  12. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    it's a stock 3/4 ton burb with a th400.
    it's right where the two pipe come together and is mounted on the top side with a one wire sensor ( no heat wire)
