Where to put the axle on the leaf springs
Discussion in 'The Garage' started by pitbulls'n'blazers, Mar 6, 2006.
  1. pitbulls'n'blazers
    pitbulls'n'blazers Registered Member
    Jan 18, 2006
    67
    Missouri
    When you take the axle off the leaf springs and put blocks or new lift springs or shackle flips, how do you know where to bolt the axle to the right place on the leaf springs??? I'm a newbie when it comes to lift kits, so your input will really help me out!!
    Thanks!!
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    The springs will have a locating pin. The head of this pin goes into a hole drilled into the spring perch, which is welded to the axle.
  3. pitbulls'n'blazers
    Jan 18, 2006
    67
    Missouri
    That was simple,Thanks man!
