Where to put the radio
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mountainibis, Feb 10, 2004.
  1. mountainibis
    mountainibis Registered Member
    Jan 29, 2003
    75
    Morrisville, NC
    So, I thought I'd step into the '90s and install a cd player into my 72. But, I'm hesitant to cut the dash to fit the cd player.
    Would I be a dumbass for cutting my dash to replace the post-style radio?
    I thought about getting a Tuffy console box and installing it there, but my floor is bed-linered, so you'd be able to see the wires running from the console to the dash, which might be too tempting for the sticky finger crowd.
    What's my best option?
  2. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    well u could run the wires from the consol to the dash and just line over them too.
    Nick
  3. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    You could build an aluminum box to mount under the dash to house the CD player so that when you don't want it in there anymore or sell it, you can unbolt it.
    Bill
  4. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Don't cut your dash /forums/images/graemlins/yikes.gif It's not worth it. /forums/images/graemlins/shame.gif
    Repairing it afterwards (and you will want to) is a fair amount of work to get it right.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Don't cut the dash!!! /forums/images/graemlins/shame.gif
    Depending on the "depth of sneakiness" you want to achieve you could:
    1. Install a stereo into a Tuffy-style console. Bolt the console securely through the floor so nobody will ever own it but you!!
    2. Install a deck under one of the seats and mount the display/controller in the ashtray so it can be hidden by simply closing the tray.
    3. Install the deck under the seat and rework the existing radio knobs to actually control the functions of the CD player (left knob = volume, right knob = trck fwd/track back) the pushbuttons for the presets could be remapped to do things like track repeat, eject, etc. I've seen installs where the display is then installed inside the rearview mirror with the reflective coating cleared away so that you have track info, etc visible in one corner of the mirror.
    Many choices.....and no cutting of the stock dash. In a 1st Gen, I consider hacking a radio hole to be a cardinal sin. /forums/images/graemlins/yikes.gif
  6. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I'd go for the cousel. second choise under the seat, or beside the seat. just don't cut the dash.
    ARQ.
  7. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    ...mount the display/controller in the ashtray so it can be hidden by simply closing the tray....
    How big is the ashtray in your ride Greg? I can fit like six pennies and a quarter in mine.
  8. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    This would fit:
    It's for marine applications, but it just so happens to plug right into the back of the Sony C90 deck....one of the nicest, high quality head units ever made.
    (Could this be a foreshadowing of a future update to the Greg72 stereo install?) /forums/images/graemlins/whistling.gif
  9. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yeeerr Sooo Tricky /forums/images/graemlins/peace.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
  10. mountainibis
    Jan 29, 2003
    75
    Morrisville, NC
    I didn't think it'd be a good idea to cut the dash. Thanks everyone for re-inforcing that for me in my moment of weakness.
    I already have the radio (freebie from my bro). If I can get a remote unit for it, I like the under the seat idea. If not, I'll probably end up getting a Tuffy console and finding a way to cover up the wires.
    Thanks again.
  11. TED
    TED Registered Member
    Nov 27, 2002
    81
    San Jose, CA
    My stereo is in a tuffy console and it works great. My rig is also lined, so to solve the wire problem I cut a hole in the floor right under the console with a hole saw and ran the wires under the floor. They run inside the frame, up the firewall and back into the cab. I used flex conduit the whole way as well as grommets when going through the holes I cut. Works great and looks clean. /forums/images/graemlins/usaflag.gif
  12. mountainibis
    Jan 29, 2003
    75
    Morrisville, NC
    I like that idea. What kind of sealant did you use around the hole under the console?
  13. TED
    Nov 27, 2002
    81
    San Jose, CA
    I didn't use any sealant. There's a ridge that runs across the floor for support (the front bolts on your seats are anchored into it) and I cut the hole in that, it's really well protected from the underside. The hole is small and filled with wire and a grommet so I'm not too worried about anything coming up through it. If I get water that high I'll have other problems. If I get some time I'll post some pics to webshots and add the link.
  14. JohnSPledg
    JohnSPledg 1/2 ton status
    Feb 22, 2001
    141
    Baton Rouge, La
    Another option would be to give up the glove box and put the head unit in there. The cardboard can't hold much of anything useful to begin with. Or, get the tuffy console and rub the wires through the floor and along the edge of the tranny tunnel then back through the firewall. If you have a full cage, you could fab a locking steel overhead console for the stereo. What ever you do, I would leave the stock radio in the dash as a decoy. I'm trying to find a working GM 8-track for mine. I plan to have the working 8-track with a stock location speaker, and my real stereo and speakers hidden through out the interior. That should keep any would be stereo thieves confused.
  15. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Sneakiest of all would be to do my "Option 3" above, but also preserve the existing function of the stock AM radio and be able to "toggle" between the BIG stereo and the AM radio with a hidden switch.
    Talk about being able to mess with people's heads.... they are sure that they heard a "real" stereo, but when you show them the dash and flick on the radio.....voila! Nice monoaural AM sounds emanating from the dashboard speaker....
    Man, I love messing with people! /forums/images/graemlins/histerical.gif
  16. Robin
    Robin 1/2 ton status
    Oct 30, 2001
    184
    Georgetown, Texas
    If you're willing to buy a new radio, LMC has an original look style with built-in tape and control for remote CD.
  17. H0BBEZ
    H0BBEZ Registered Member
    Sep 19, 2001
    38
    Frederick, CO
    I'm going to have to disagree with everyone here ... /forums/images/graemlins/yikes.gif ...to a point. If you really are going to try keeping a stock look either now or in the future, great, don't cut the dash.
    However, in my own vehicle I wouldn't put up with the extra clutter of a stock radio for the added "security". Especially when it means giving up the most convenient spot for navigable stereo. (Might be worth noting that in my vehicle I'd be counting on a pretty dumb thief to see the stock radio but overlook two big carpeted boxes in the back.) I would also rather have my dash cut with a clean install of a new deck than have empty stock holes in the dash for the life of the truck.
  18. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you do cut the dash just cut it top and bottom and fold the sides back. That way if you ever want to go back all you have to do it bend them back and weld it up.
