Where's my check engine light?
Discussion in 'The Garage' started by PonchoCatalina, Jun 23, 2005.
  1. PonchoCatalina
    PonchoCatalina Registered Member
    Feb 8, 2005
    18
    College Station, Texas
    My '86 Suburban has been running rich, so I figured that I would check for trouble codes. I prepared my special computer-code-deciphering paper clip and entered the vehicle only to find that I don't seem to have a check engine light. I checked my owner's manual, and where it shows the light (high and between the speedo and gas gauge), there is nothing - just smooth faux aluminum cluster facade. The manual indicates that only California light duty emissions and federal heavy duty emissions vehicles had the CEL's. What gives? - since my Suburban is a half-ton, non-California vehicle, is there indeed no light? Thanks for your thoughts on this.
  2. dyeager535
    26,975
    Shouldn't be a CEL, do you have an O2 sensor or ALDL connector under the dash for your paperclip? I suspect not on both accounts.
  3. PonchoCatalina
    Feb 8, 2005
    18
    All I found under the dash was a small black box housing a printed circuit board with a multi-port plug attached to it (beneath the radio). It did not appear to have an ALDL port. Is there no ALDL port on a 1986 light-duty Suburban?
  4. dyeager535
    26,975
    Only CA and TBI trucks would have a CEL. Computer controlled carb is what would get an '86 a CEL/ALDL. You don't need/get a CEL without an ECM to notice a problem.
    Sounds like a CA '86 would have the CEL light in the diesel wait light location (or is that water in fuel light?) while the choke light was in the normal location. 1987+ the CEL replaced the choke light, in the same location of course.
  5. PonchoCatalina
    Feb 8, 2005
    18
  6. dyeager535
    26,975
    Yes, CCC/TBI all have ECM's, thus CEL. (and ALDL)
  7. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,921
    331
    Fort McMurray, Alberta
    For my truck, the SES is one of the idiot lights under the speedo. There is a chance that your bulb may be burnt out :)
