Wheres My Luck!!!!
Discussion in 'The Lounge' started by 84gmcjimmy, Mar 1, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Now our microwave is acting dumb. My mom went to use it today, and she says" I turned it on then it made a weird noise, then it started to smell like burning rubber"
    What has happened? Anything? :confused:
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    ours did that one day, then quit, then the next it started pourin black smoke out the vents, Id quit using it and find a new one lol.
  3. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    Cover your nuts and use it tell it breaks!:p:
  4. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    I dunno, I have an extra microwave, I can send that up, it's old and used though
  5. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    every once in a while ours looks like there is a spoon in it. just heating up a pork chop.:confused:
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Sounds like it threw the belt on the wave invertor, that's the part that takes the macrowaves in the air around you and converts them to microwaves so they fit into your food. Just open that bad boy up and put a new drive belt on the convertor cog, it'll be real obvious once you get it opened up.
  7. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You know, that was good enough to make me wonder if you're serious
  8. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    what about the flux capasiter?
    and dont tell steve that he'd find a way to nuke him self!
  9. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Im gonna guess its the percolator that went bad. Its what percolates the waves into your food after they've been converted from macrowaves to microwaves.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    So I have to take the cover off? micro wave...my breakfast is no more! no oatmeeal:crazy:
  11. 502
    502 1/2 ton status
    Sep 9, 2004
    179
    California usually
    In all honesty, the microwave should not be used or even plugged in for that matter. Unless your microwave was manufactured in the early eighties, you will not find a wave inverter in it. They were discontinued because of inherent problems with the early cog belt retensioning sub-system.
    Most likely the problem is with the cut-off before the shut-off servo. It's about 10cm in diameter and is filled with a low-pressure neon gas. If you take off the rear cover you'll see that it is shaped sorta like a small bottle of pancake syrup. Right beside it you'll notice a piece of graphite about six inches long and it will look like it is incased in wood. This is the bypolar transister frequency multiplier or simply BTFM. One end should have what looks like a rubber cap and the other end should come to a sharp point.
    If that point is sufficiently dull or broken, your microwave is shot. There is a special point resharpening tool that looks alot like a pencil sharpener, but its proper use is more than likely beyond the scope of the do-it-yourselfer.:)
  12. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    That's true, although you'll find some high-end units today that still use the wave inverter design. They've taken care of the design issues by using high strength materials, such as unobtainium and injection-molded kevlar. Nice units though, they'll dry an average sized poodle in under a minute.
  13. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Check the batterys. Thats what was wrong with mine. Took two small golf cart batteries to jump it. But I have the reversable 220v model... Kinda like the one on Gilligans Island.
  14. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Magic
    Have a look at the Voodoo meter. If it gets too low you'll need to kill a chicken and do the zombie dance in order to refill it.
  15. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    come on guys, this is a rather serious thing to be playing with, be serious. FYI Steve, the BTFM will look almost like a pencil. dont try to remove it and write with it though, if you do, it will never work again.
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    my mom must thing we're rich:confused:
    she bought a new one. New printer and new micromave in 3 days:confused:
    anyways, I'll take the cover off and see if I can understand what ou guys are talking about.
    Is there a chance I could harm my self when I touch something inside the cover?
