wheres my mileage????
Discussion in '1982-Present GM Diesel' started by 55Willy, Mar 6, 2003.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    89 6.2 with 108,000 miles + th400 + 35's + 4.10's = 12 MPG
    I was looking for 15-17MPG with this. /forums/images/graemlins/confused.gif
    wheres all of it going?
    air filter and fuel filter are new.
    -Jeremy
    "The DEEZEL newbie"
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    well, are you doing alot of hwy driving, are you on the skinny pedal hard? rember diesels have a lower redline than gassers, you need to keep the rpm's lower to get the milage. If your tires are a true 35" your engine is turning at about 2560rpms at 65, the ideal rpm range for best mpg is around 2000.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    He got it.
    /forums/images/graemlins/thumb.gif
    I get 30MPG around town and 20MPG on HWY running 70MPH with 35" / 465 / 308 gears.
    I am around 1800RPM's
  4. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    hhhmmm I need a tach.
  5. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I don't have the tach yet and I want one but I did the math like he did.
  6. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    Or I could throw on some 38's to take the rpm's back down,LMAO
  7. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's what I did.
    Mine topped at 60 with the 33" tires so I went bigger.
    and my mileage got better.
  8. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    I saw a formula somewhere that showed how the mileage in a diesel went down for every 100 rpms over a certain number you went. It was pretty cool. Anybody else seen that around? I'll see if I can find it.
  9. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    went back and dug this one up, I'm adding in a set of 373 axles soon so I can get the mileage I wanted.
    I went with 373's sicne I already had em laying around and the rear is a full floater instead of a semi. /forums/images/graemlins/smile.gif
    i'll see the difference once i run it up to portland (same trip I got 12 on)
  10. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    SUCKER!!!
    and you know what im talking bout....
    grant
  11. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I know what your talking about, but I never took the burb there /forums/images/graemlins/pimp1.gif
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    does a blazer have a good passing ability with say a 6.2 35's and 3.08?? i know they arent speed demons anyway but i would like to be able to pass someone. does the higher numerically lower gears affect this?? I have 4.56 now and they will definatley have to go once i get my diesel in there i see already.
  13. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would say the passing ability isn't going to be good.
    It would get you great mileage but it will be a dog.
    I get 30MPG with this setup now but I am putting 3.73's and I will let you know how it goes.
    Now Semis will pass me uphill. I am hoping I will be able to pass them.
  14. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    do you have anylift or is it all fender trimming?
  15. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's a 2" lift and lots of trimming.
