Wheres the heater fan?
Discussion in 'The Garage' started by protechk5, Dec 13, 2006.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    On my 6.2 with no AC, my heater and defroster doesnt blow. None of my fuses are bad. Where is the fan for this? How do you get to it?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Open the hood and look on the pass side firewall. You will see the round motor housing. It is only accessed that way. You can not get to it from under the dash so don't bother trying
  3. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Its hidden on diesels...!
    Most diesels had a plastic cover over the entire firewall to hold insulation and reduce noise..the heater blower is in the same spot as other trucks,but will be buried beneath this plastic covering(if it hasn't been removed already that is!)..my 82 K20 diesel evidently had its blower motor serviced or replaced--the butcher who did the job just used a hammer to crack the plastic away from the heater box area..:surepal: --some "mechanix" shouldn't be allowed under a hood!..:mad:
  4. BadBob
    BadBob 1/2 ton status
    Aug 14, 2005
    158
    Lyndon, KS
    Mine did too, but it crumbled into dust! You might take a look at the resistor block too, those like to go bad on occasion, and they're cheap to replace.
