Where's the VIN on a 74 Burb???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Aug 24, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Where\'s the VIN on a 74 Burb???
    I can't locate the VIN tag on a friends 74 Suburban. Anyone know where it is?
    Thanks,
    Eric M.
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    Re: Where\'s the VIN on a 74 Burb???
    Where did you look? It should be in the drivers side dash. Viewable from the windshield.
  3. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Later model trucks and Burbs have them on the dash, not the earlier versions. I'm not sure what year they changed, but it was before 1980 and after 1974.
    Anyone else have a 74 or there abouts with the VIN somewhere other than the dash?
    Eric M.
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    My dad's old 73 had it in one of the door jams, forget which one. I think it was either the driver's door or the driver's passenger door.
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    Old Camaros and Firebirds had a cowl tag with the vin. Maybe it has one of those under the hood...
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    88 K5 Jimmy,
    Was the one on your dads 73 just a sticker or was it a plate? I found the sticker, it's barely legable - there's gotta more than that!
    Thanks,
    Eric M.
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Ok, i have a 75 burb, and I have a VIN in 3 locations.
    1st is on the dash like everyone else has
    2nd is on the drivers side, back seat door frame just above the striker bolt (metal plate)
    3rd on is on the frame, pass side, top of frame rail, in front of the rear spring front hanger about 8"
    Does that help you out? /forums/images/graemlins/thumb.gif
  8. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    73 to 78...left side door frame..cab side...below striker.
    79 to 91 c/k/r/v under dash pad drivers side on dash structure.
    DW
  9. limey
    limey 1/2 ton status
    Dec 17, 2002
    121
    midland texal
    my 74 jimmy was on the doorjam wich is good because i riped out the dash and put in a flat dash.
