Whew.... Catastrophe Avoided!
Discussion in 'The Garage' started by bluehen, Mar 27, 2007.
  1. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Had some intermittent squealing from one of my v-belts. I figured it was prob the alternator belt since it would mostly do it under an electrical load. Popped the hood this weekend and got a chill from what I saw. The pivot bolt on the alternator had come loose ( or wasn't tightened properly when I replaced the belts) and was inches away from the fan. I can only imagine the damage that sucker would have done if the bolt reached the fan. Fortunately it's all under check, belt tension back to where it should be, and the only squealing is from the passengers. :o
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I had a fan blade fly off once while I was driving. I saw the hood pop up a bit, then there was a small dent from underneath, I didn't know what it was at first. I pulled off, everything looked ok, continued driving, in about 100 miles, the water pump went and that's when I noticed the fan was no longer balanced. :eek:
  3. nemesis_pyros
    nemesis_pyros 1/2 ton status
    Mar 24, 2004
    229
    Winnipeg, Manitoba
    Had a fan blade let go at about 3000 rpm in my '49 chev p/u. Heard a LOUD bang and then got all sorts of vibrations. Pulled into the gas station and found the blade stuck half way through the inner fender. Good thing mine didn't go through the hood.
