Which 14 bolt is this?
Discussion in 'The Garage' started by bugspray, Nov 22, 2004.
  1. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    My buddy is looking to buy a locker, but we want to make sure which one it is first. Is it the SF? 14 bolt pics The FF is 10.5 and the SF is 9.5, right?
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Yes and yes.
  4. bugspray
    Jan 13, 2004
    110
    Phx, Az
    Thanks guys.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What kind of locker is he getting ?
  6. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    SF. Also looks like there may have been some water in the gear oil.
  7. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    That is a sf. For future reference though, pulling the cover is not the best way to tell. Next time, save yourself the trouble and just look at the hub. If the hub has 8 bolts in a circular pattern around it, its a ff, if not, its a sf. /forums/images/graemlins/wink.gif
    -Harrison
  8. bugspray
    Jan 13, 2004
    110
    Phx, Az
    He needed to change the fluid in it anyway, but thanks for the info for future id. I didn't watch him drain it to see if there was water in it, but it had been raining all day.
    He wants to get a Detroit Locker. Someone at a 4 wheel parts store told him he would also need new bearings etc. I haven't ever heard anything about that. Can't you just stick it in without replacing anything else generally?
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    If he goes with a Tractech Loc-Rite(a "drop in" locker), then he just install it without doing the bearings. If he gets a Detorit Locker, then it is best to replace the carrier bearings at the same time.
    *EDIT* With the Detroit, you'll also have to set-up the ring and pinion again...
