Which "add a leaf"?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chvyhs, Jan 3, 2002.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Which \"add a leaf\"?
    I have a '90 3/4Ton Sub with 6" springs in the front and 4" blocks in the rear. I want to get the back up 2-3". I've heard that the long leaves flex better than the short. I also heard that the "add a leaf's" settle too. I pull a trailer sometimes, thats why I want the back a little high. What can you tell me about a 6" spring for the rear? Will they handle a load as well as the stock springs?
    Here's Summit Racing's springs <a target="_blank" href=http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpart%26Part%3Dexp-13122%26Search.x%3D1%26SearchType%3DBoth >http://store.summitracing.com/defau...art&Part=exp-13122&Search.x=1&SearchType=Both </a>
    or
    <a target="_blank" href=http://store.summitracing.com/default.asp?target=search.asp%3FType%3Dbysummitpart%26Part%3Dexp-13122%26Search.x%3D1%26SearchType%3DBoth>http://store.summitracing.com/defau...xp-13122&Search.x=1&SearchType=Both</a>
    Thanks.
    <a target="_blank" href=http://community.webshots.com/user/chvyhs>WebShot Pics</a>
  2. holyjohnson
    holyjohnson Registered Member
    Nov 22, 2001
    94
    the fringe of insanity (only on mondays)
    Re: Which \"add a leaf\"?
    have you considered a rear shackle flip.i think ORD makes them with like a 4" and 2 1/2" lift from what ive heard it offers good articulation and less axle wrap then rear blocks.may have to do some research to know exactly if you can run blocks and flipped shackles but i think the flip kit runs under $200 and is stronger then the stockers.but i havent tried them so just an idea.goodluck.
    www.offroaddesign.com
    "well,are you gonna pull them pistols,or whistle dixie!?"
  3. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    Re: Which
    i'm doing some ORD 1" Add A Leaves soon they have NO effect on spring rate.
    Hows my driving? call 1-800-EAT-DIRT
    --Scott, 1989 GMC Suburban 2500 4" lift, 36" TSLs
