Which arm for d60 crossover with 52's
Discussion in 'The Garage' started by garlicbreath, Jun 4, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I swapped in 52's on my 71 blazer and need to choose a D60 crossover steering arm. Do I need to go highsteer? I wouldn't mind but money is tight and that would mean lots of new parts. Does the tie rod need to go behind the axle? There are lots of threads for 73+ but not for first gens.
  2. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    I don't have a 1st Gen but my vote is for the NWF arm. :wink1:
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have ORDs crossover and it will work with 52s even though I do not have them. It is an excellent product but if I had to do it over again I would go ahead and buy the Highsteer arms for the tie rod behind the axle, that way there will be no problems with draglink to tierod clearance.
    Just my .02
    Ira
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would get the arms that put the tie rod behind the axle too. If you go more extreme in the future than you are covered. If money is tight then just get the pass arm and get the drivers later
  5. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
  6. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Another vote for NWF. They are the tallest arms I have seen
  7. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Small hi-jack not really are the NWF arms tall enough to clear zero-rates with 52's and an overload?
  8. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    I've got 56s up front with a shakerbuilt arm. The draglink touches the spring at full lock. I'm thinking of going with skys arms. They're pretty thick, and should allow for more clearance.
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    Well I was going to go with Sky too, but now I am thinking. Anybody got a side by side comparison?
  10. readymix
    May 30, 2004
    6,706
    26
    I think so. Can measure if you would like to give you an idea.
  11. RGV72BLAZER
    RGV72BLAZER 1/2 ton status
    Jan 23, 2006
    2,425
    Edinburg*San Bene*Online-The Real South Texas
    ...i'll be getting my hysteer kit from Sky tomorrow...but won't be able to test it out with the 52s on my '72 until i can get the body back on which will probably in the next month...hopefully i don't run into any problems...lol...
  12. garlicbreath
    May 17, 2003
    1,136
    Denver
    I have 5 leaf packs with the overload cut down and an extra leaf from my old 6 inch skyjacker springs. Maybe we could start a "measure your arm" thread and have people measure the height from the top of the kingpin to the tie rod mounting surface.
  13. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
  14. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    I guarantee it. I've got one of our arms, a lifted 52" spring pack and left the overload in. Loads of space left.
  15. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    NWF or WFO, either way... good stuff good people.
    Not sure why people worry about steering arms thickness quite so much... my WFO arm is 1" thick and I have a sneaking suspicion that it is stronger than my stock knuckles are. Anything more than that, unless you've gone to Deadenbear knuckles, would seem like overkill. I run ARP studs and my guess is the knuckle will be the first thing to go.
    j
  16. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    1" Arm thickness is fairly standard, as it is what is required by the taper of the TRE to fit properly. Height will make the larger difference as far as compatiblity with thick spring packs.
    -Kyle
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I was worried about it because on my 10b I had to get a 1" spacer to clear my springs with my D/L:crazy: I don't know how much taller a 60 knuckle is, but it is a concern with 52's an overload and maybe a zero rate what kind of clearance issues may arise.
  18. garlicbreath
    May 17, 2003
    1,136
    Denver
    I went with WFO. Got their highsteer passenger arm. Will get the drivers later when money walks into my wallet. Guy was nice to deal with.
