Which auto tranny is the best?
Discussion in 'The Garage' started by adamforsythe, Dec 16, 2005.
which tranny should I use?
  1. Th400
    52 vote(s)
    42.6%
  2. Th350
    12 vote(s)
    9.8%
  3. 4L60E
    0 vote(s)
    0.0%
  4. 700R4
    21 vote(s)
    17.2%
  5. 4L60
    2 vote(s)
    1.6%
  6. 4L80E
    22 vote(s)
    18.0%
  7. Allison T-100
    12 vote(s)
    9.8%
  8. powerglide
    1 vote(s)
    0.8%
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    What tranny would be best for my truck? mudding, street, light off roading (I.E. Hunting, camping, ect). The power plant will be a 350 4 bolt pushing around 450HP with 3.73 and a Np205 maby a doubler.
    Adam
  2. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    4L60 and 700-R4 are the same transmission. 4L60E's an electronic version of the 4L60. 4L80E's a slightly modernized, electronic-overdrive version of the TH400.
    Based on your engine's power levels, I'd go with either a TH400 or a 4L80E if you NEED an overdrive along with the strength.
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    You can easilly get a 700R4 to handle the power. And you'll have an OD thats not all electronic. If you dont care about an OD go TH-350 or 400. An Alison would rock!! What size tire? I would only do 3.73 if I wasnt going much over 33" I run 35's with 450 HP 383 and 4.10's. My last Blazer was 383 700R4 and 4.56's and I think that was great for 35's. After 37's I would go to 4.88's
  4. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    dont mean to high jack.....but does the 4L80E tranny have the same spline count and bolt pattern as th400???
  5. Inu-Hanyou1776
    Oct 1, 2005
    1,345
    Murphy, NC
    You talking T-case bolt-pattern?
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
  7. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I was going to be a smart ass and say a power-glide with a 3500 stall but from what your usage sounds like if you want overdrive go with a 4L80E or if you only need a 3 speed go with a TH-350 (you can beat them like a dead horse and they don't complain)
  8. AussieK5
    AussieK5 1/2 ton status
    Jun 17, 2001
    316
    A land girt by sea
    Just out of interests sake if your considering the dollars involved for the higher end OD trannies. .......I costed out my yearly mileage non-OD vs OD.
    Assuming I would spend 40% (probably much less) of my time in OD over the course of a years driving, I would save the grand total of $240.
    Or to put it in real terms I would see a 14% saving on fuel cost per annum ($2500 down to $2140).
    A cheap rebuild on an existing 350/400 is looking real good in financial terms.
    Jason
    Note: Engine wear is not considered and may be, for you, like me, irrelevant.
  9. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    700r4 = sucks
    T-400 = rocks
  10. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    Why do you say th350? A th350 is basically every bit as strong/weak as a 700r4 but without OD.
    The 700r4 will handle the power with some extra $$$ and parts like the corvette stuff and stouter clutch packs but you can never go too beefy with a tranny.
    th400 or 4l80E all the way.
  11. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    I love how so many have voted for the TH400... its got quite the cult following, even though in this situation it is obviously not the right choice. light wheeling and street driving? common guys...
    my opinion is that the 700r4 is your best bet... if you can spare the coin (quite a few of them...), then 4l80e
  12. Jimmy4matt
    Jimmy4matt Registered Member
    Feb 7, 2005
    74
    Campbell, California
    I've had bad experiences with the 700r4, good with the th350, and good with the Allison 1000. The Allison had a hefty OD run, short gears. I'd go 4.88 with 35's, 5.13 with 37"+. My Jimmy is comfortable on the highway with th350, 4.10, 35" The Allison only felt good in Tow/Haul mode otherwise it felt like it was robbing about a hundred horses. Good luck if you go Allison. Electronic controlled and all.
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    ive got 5.13s currently with 35's with a 700r4. cant say how it drives, its still in the process of being put back together. ill report back within the week
  14. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    You can build most tranny's to be bombproof, but I prefer the one that was built at GM to be bombproof. But an OD in the TH400 would be nice ocassionally.
  15. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    assuming gearing is well chosen for the given tire height, there is no reason at all that the th400 can't be used on a street/light wheelin rig. They are hella stout and rebuilding them is dirt cheap compared to a 700R4.
    j
  16. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    I got my 700 rebuilt for $300.
