which axle to use 14 bolt or dana 60
Discussion in 'The Garage' started by dirty willy, Apr 21, 2004.
  1. dirty willy
    dirty willy Registered Member
    Apr 20, 2004
    6
    Ontario Canada
    still trying to figure things out on my machine. it is just off road use. 74 blazer frame, 75 3/4 ton axles (dana 44 & 14 bolt 10.5) 4.10 gears 44" boggers 350/350/203. mild cam small stall, all tube body seats 4 Question is it needs more gear 5.13 is tops for the 14 bolt should I go to a different rear end, dana 60 or 70? then I could run 5.88 gears. /forums/images/graemlins/dunno.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    You could keep the 14 and get a Doubler.... /forums/images/graemlins/laugh.gif
  3. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i think the dana's might be able to go lower than 5.88's, i thought i've seen 6 something, but then you have gear strength issues, i would definately go as low as possible, and if you have the options, maybe a d70, if its trail only though you dont have to worry about lockers, so maybe a 14FF welded or detroit and a doubler. anyway i dont know if that helped, i'm sure someone else may chime in and correct some of my errors /forums/images/graemlins/whistling.gif /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    D60s will go to 7.17
  5. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Can;t say I'd want to run that low of a gear though, you'd be winding out big time even with some 44s, and I can't picture there being a whole lot of strength in that many teeth.
  6. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    but LOW LOW LOW gears on a D44 isent a good idea espically with 44 BOGGERS you wont have much gear mesh
  7. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    didn't even notice that, definetally wouldn't want to run 5.88s on a dana 44 with 44s, heck I wouldn't want to run 2.73s, D44 and 44s.
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ]Ditto. /forums/images/graemlins/waytogo.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I just realized it was a Dana 44 front. Oops...
    I'd be looking for '60 front or a smaller set of tires, or both, in a hurry!
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Go doubler and get a heavier set up on the front. The lower gears 5.whatever and lower have such a small pinion that it can strip easily. That is why 4.56's and 4.10's are so common. The doubler makes up for it.
  11. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    ditch the th350 for a sm465. regear the 14 bolt and 44 with 5.13s and never look back.
  12. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, dont look back, and you'll never notice the pieces of your front axle you left on the road. Dana 44 is a model number, and has nothing to do with the size of tire it will support. you wont catch me with anything bigger than a 36 x 12.50 on a 10 bolt or D44. i've heard too many horror stories.
