Which ball joints?
Discussion in 'The Garage' started by johnathan, Apr 6, 2006.
Which ball joint should I go with?
Poll closed Apr 9, 2006.
  1. MOOG
    20 vote(s)
    76.9%
  2. SPICER
    1 vote(s)
    3.8%
  3. DON"T KNOW
    3 vote(s)
    11.5%
  4. REALLY DON"T EVEN CARE
    2 vote(s)
    7.7%
  1. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Bout to do the ball joints.Which one should I go with???
  2. BizeeB65
    BizeeB65 1/2 ton status
    Oct 12, 2005
    859
    Louisville, KY
    You left out the nekked choice from the poll.... :deal:
  3. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    I nekkidly choose Napa gold.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Moog all the way :thumb:
  5. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    O.K O.K I'm naked
  6. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    Moog Moog Moog:D
  7. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    The ones with the lifetime warranty :D
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I just installed moogs in mine. They were high quality.
  9. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Moooooog it is then:D
  10. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    Where can you buy the Moog joints?
  11. BizeeB65
    Oct 12, 2005
    859
    Louisville, KY
    summitracing.com
  12. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
  13. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    how bout a king pin option ;)
    moog
  14. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    :D Tell me more:D Kingpins on a 10 bolt hmmm???
  15. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    Uppers MOOG, only ones that are greasable...
    The upper's on Moog have grease fittings on the side. All the others hace a plug/scrap! The lowers are $25 from GM. Cheaper than Moog! Just put one Chinese in mine, then figured out to try GM. DUH... :eek1:
  16. uglytruk
    Oct 24, 2004
    1,329
    Can you see the side hole? I positioned one fitting forward and one rear, but not too far, check clearance from knuckle. Grease both w/o turning wheel. Doesn't have to be at 4: o'clock, 3:00 is good. Will post pix... I also had some longggg grease fittings. No idea where I got them from.
  17. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    Carquest and they come with a lifetime warranty (just don't lose the reciept)
    Moogs are better alone on there zerk design. The upper joint has the zerk off to the side so you can always lube them.
  18. uglytruk
    Oct 24, 2004
    1,329
    Here they are...
    Wheel cranked left, drivers gr fitting points forward, pass side gr fitting points rear! Makes the job so much easier...
  19. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Wow not to be a dick, but it doesn't look like anything on that front axle needs to be greased anymore:eek1: Got a small leak?:crazy:
  20. johnathan
    Sep 26, 2005
    376
    Ocean Springs,MS
    :D Awesome Thanks for the info:D Sounds like the way to go!!!!!
