which bellhousing???
Discussion in 'The Garage' started by az ranger, Jan 24, 2005.
  1. az ranger
    az ranger 1/2 ton status
    May 9, 2004
    139
    Safford AZ
    I need hydrolic bell to do 465 swap I can't find one on 85-87 applications. If I found one in a 88-92 pick up with the 4 speed would that still work in my 88 jimmy Are all of the hydrolic bellhousings aluminum?
    thanks
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    yeah hydro bellhousings are aluminum. I remember my friends talking about the slave on a 88+ being on the opposite side. That could easily be bull. If its on the right side it should work.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    It is on the oppsite side but its also for the 5 speed tranny.
    The older ones that you found should work fine. :grin:
  4. dyeager535
    26,980
    465 was used in the 88+ body for at least one year, not all manual trucks '88+ were 5 speeds.
  5. az ranger
    May 9, 2004
    139
    Safford AZ
    which side should the slave mount to the bell housing on for 85-87. I found one on a 89 that still had the 4 speed the slave on that mounted onto the driver side.
    Could I still use this one? what difference does it make where it is at as long as it is there, Right or am I wrong?
  6. dyeager535
    26,980
    Slave is DS for the 73-87(91) trucks.
    If you can get it, look for a casting or part number on it, and if its a PN, can be checked against my parts manual diagram/part number listing below.
    http://dyeager535.topcities.com/partsmanual.html
