which brake hoses are you using?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Jun 27, 2001.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    just curious as to what brake hoses everyones using with their rear disc setup with 14 bolt, especially the caddy calipers.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I do NOT have the caddy calipers. I have the GM calipers (no ebrake.)
    You have to make the rear brake lines. Here's what you do. You need to have your rear brake line with you when you go to the parts store (I went to Autozone.) Tell them you want the FRONT brake lines for a 70's Blazer k10. Then tell them you need two lengths of steel brake line with the correct fittings to go between your new rubber brake line and your brake line you brought with you. They are about $3 to $4 each, with fittings. You then need a simple tubing bender (about $5) and a flare tool (again, like $5) to cut and bend it the way you want it. I hadn't ever made brake lines before I converted to discs, but it was pretty easy.
    In case you're wondering how to get your dirty rear brake line off your truck and onto the Autozone counter, don't worry. Go buy the braided Stainless Steel brake lines from ProComp (made by Earl's) because it replaces your rubber line with the braided line.
    I hope that wasn't confusing...
    -- Mike
