Which brake lines again???
Discussion in 'The Garage' started by 8_YOUR_H2, Nov 5, 2002.
  1. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    I am getting ready to order some of the superlift brake lines tonight but they dont say anything about a 1 ton. Now, If I remember correctly I can buy the ones for a 1/2 ton with a 10 bolt and they will work on the D60 right? Is that the case for the "Bendix" brakes too?
    Brent
  2. K5DRAGER
    K5DRAGER 1/2 ton status
    Jul 27, 2001
    1,164
    Momence, IL
    If your talking about the real long ones I just got mine the other day. Front ones are 11" longer than stock..3096-11 says they are for 87-91 front GM. The rear ones are 10" longer than stock..3093-10 says they are for rear 71-92 GM /forums/images/graemlins/grin.gif
  3. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Funny you should mention that since UPS just delivered my Skyjacker brakelines.
    Skyjacker part no. is FBL29
    I measure them at 26" long, braided SS, with a clear plastic cover over them.
    I measured my stockers and they were about 21" long. Kind of odd since this is supposed to be for trucks with 6 - 8 " of lift, but we'll see.
    RBL21 Stainless Steel Brake Line; Rear; Rear; Lift Height 3 in. - 4 in.; Single;
    RBL20 Stainless Steel Brake Line; Rear; Rear; Lift Height 6 in. - 8 in.; Single;
    FBL29 Stainless Steel Brake Line; Front; Front; Lift Height 6 in. - 8 in.; Pair;
    FBL27 Stainless Steel Brake Line; Front; Front; Lift Height 3 in. - 4 in.; Pair;
    -- Mike
