Which Brake Master Cyl. ?
Discussion in 'The Garage' started by crazy427, Feb 12, 2005.
  1. crazy427
    crazy427 1/2 ton status
    Mar 10, 2003
    979
    Edison , NJ
    On a 89 k5 silverado Im Running my stock master cyl. I have stock brakes on my 10 bolt up front and in running a 14bff in the rear. My brakes master is goin so i wanted to upgrade but im not sure which 1 i should go with or what brand. i called the part store and they list 3 different ones for the different gvw of chevy trucks. Has anyone else done a master upgrade that could point me in the right direction.
    thanks
  2. wraenking
    wraenking 1/2 ton status
    Apr 30, 2003
    1,493
    Toms River, NJ
    joe, whats the reason for upgrading. i had to get a new one caus ei blew mine out bleeding the brakes, and i went with the stock master and they work awesome with the disc swap. i just upgraded the prop valve
  3. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    Im just curious,My truck was stopping fine for the past few months. i noticed a big improvment when i swapped in the 14bolt becuase of the larger brakes. But now that it is goin i figured a truck that has larger brakes must have a larger master cylinder to go with it to compensate for the extra pressure they are goin to be put under.3 are listed but the part store cant tell me the exact difference between them: if the bore size is different, if the mounting is different or if they just hold more fluid. so i want to see if anyone else did a swap like this , if they ran into any problems or it wast worth the effort to try and make it work.( the real reason is i like to play and cuase myself headaches...lol)
  4. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    i see. i remember reading a bunch on it when i did a search, but now i cant find it again. ill let you know if i do.
    and let me know what you end up doing
  5. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    Thats cool, Hey how is your monster coming along?
  6. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
    im driving! i didnt realoze for some reason i had to have the caddy caliper e brakes adjuste before they would work right. i had a soft pedal because they were out of whack. today im finishing another lift with my buddies new blazer, and then hes gonna look at my kick down cable. seems to be a little rough. after that, i need to put a tach in to see what im running at.
    oh, then i need to :hack: some more. a couple of times when turning and hitting a bump, the tires hit in the front
  7. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    How do ya adjust calipers? I thought they would be self adjusting.
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    some masters will have a bigger back side and wont fit in the smaller booster and that needs to be checked first. 1/2 ton unit with adj porp valve should be o.k.
  9. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    When I installed my 3/4ton axles under my burb with the rear disks, I upgraded the master to a 3/4ton master of the same vintage.
  10. wraenking
    Apr 30, 2003
    1,493
    Toms River, NJ
  11. crazy427
    Mar 10, 2003
    979
    Edison , NJ
    was there any difference in size or perfomance?
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Size wise, it bolts right on, the rear brakes has a bigger res. on the m/c. Performance wish, I felt a little bit better stopping power.
