Which brand of lift kit should I get?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bikejunkie, Jan 9, 2003.
  1. bikejunkie
    bikejunkie Registered Member
    Sep 3, 2002
    98
    Austin, TX
    I have an 85 Blazer. It needs a lift bad. I do alot of local crawling around near my house. I'm looking for a 6'' lift kit that is not to stiff. I want something that will give me lots of flex. I've been told locally that Pro Comp is the way to go but I'm still undecided. Any suggestions? thanks
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    For soft I would go with the tuff country EZ's. Check out ORD site he carries them
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    BDS, BDS, or then there is also BDS.
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    i agree w/ the tuff country ez springs
  5. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Most people say that Pro Comp is a stiff spring and Rough Country also. This will get it back to the top for more opinions. Are you going all springs or blocks or shackle flip in the rear?
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    I have Tuff Country 4" and love it. Here is a pic of the springs flexing:
  7. racercrazy
    racercrazy 1/2 ton status
    Dec 29, 2001
    145
    O\' Fallon, MO 63366
    I have Superlift springs and the front of my Blazer bounces all over the place. /forums/images/graemlins/frown.gif Looking for something else. /forums/images/graemlins/thumb.gif
  8. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    If you can afford em, Nationals are the best.
  9. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I just switched from the Superlift to the Tuff Country EZ rides and I like them better. Nice soft spring rate. I run a 6" lift.
  10. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    I'd go with the tuff country Ez's. Allthough it is cooler to tell people that you have Big Dicks Suspension (BDS)
  11. bikejunkie
    Sep 3, 2002
    98
    Austin, TX
    Thanks everyone for your option. I'm actually looking into the BDS kit, either the 6" or possibly the 8". I will be using springs in the rear. Do your think an 8" kit is to much for 35" tires. I'd like to go bigger but I'm worried my 10 bolt axles can handle bigger. thanks
  12. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Why not do a axle swap at the same time ??? 3/4 Ton axles can be had fairly cheap. If you can get a Dana 60, all the better. /forums/images/graemlins/thumb.gif
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You said you wanted flex, so stay at 6" or under. Anything higher than that won't flex nearly as well since they start getting too much arch in them. </font color>
  14. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    Is this ever going to end????
    Brandy
  15. abusedtrucks
    abusedtrucks Registered Member
    May 11, 2002
    76
    Upsala , MN
    I've got 6" BDS springs with Rancho shocks.. the shocks don't even matter though because those springs are so fu&amp;*(^ing stiff that I don't even need shocks. If you want flex, go with the SkyJacker kit. It is the best. I like my BDS springs, but if you want flex, you'll be extremely disappointed.
  16. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I did a 4" Tuff Country EZ ride w/ a shackle flip in the rear. Basically a week after I got the truck done, I went to paragon and got though all the easy/moderate stuff. it flexed nicely. and now the springs are broken in, so I can only imagine what they could do now!
  17. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I mentioned the axle swap becouse he was talking about going with tires larger then 35". /forums/images/graemlins/deal.gif
  18. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    for flex id go with the BDS...mine are in the mail, 6" for 35's. i also looked into custom made alcans, but they were $180 a spring....may be worth it. the spring rate on the BDS is around 415...i think there is a spec sheet in the tech section of this site if you wanted to compare.
    Ryan
  19. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I'll throw another name in the mix! Rancho Softrides. I'm either getting Ranchos or tuff country, which ever I can find and afford at the time I get around to doing it! haha
    I heard Rough Country has a Luxury Ride spring also, But I know nothing about them! /forums/images/graemlins/ignore.gif
    Good luck, post up here when you get yours!
