Which cam for mostly stock tbi 350?
Discussion in 'The Garage' started by 1990k5fan, Apr 14, 2007.
Which one would you recommend?
  1. XE249H Cam & Kit
    5 vote(s)
    71.4%
  2. Edelbrock Performer EDL-2102
    1 vote(s)
    14.3%
  3. Stay stock, you won't notice the difference
    1 vote(s)
    14.3%
  1. 1990k5fan
    1990k5fan 1/2 ton status
    Jul 7, 2006
    217
    Gilroy, CA
    I'm looking into buying an aftermarket cam and was wondering which would be the best for my truck.
    I have all the cheap mods done to it like the injector spacers, tbi spacer, fuel pressure regulator and such.
    Which of these two cams will give the best performance for the money.
    http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=K12-249-4
    This one was recommended by a few people on here a while back.
    http://store.summitracing.com/partdetail.asp?part=EDL%2D2102&autoview=sku
    And this one was recommended by brian at www.tbichips.com
    My last final question is, how much noticable difference will I see with a set of cam and lifters? Will I really beable to tell after install?
  2. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    The Edelbrock one will land you a free chip from them. Probably not as good as one the TBIChips will burn you though.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    And just to let everyone know, this is for a new crate shortblock he is intending to buy which has 9.7:1 compression with 64cc heads. He forgets to mention the important parts. :D
  4. 1fastchevy
    1fastchevy Registered Member
    Mar 2, 2007
    50
    Houston
    If it's a new motor and he has never driven it he will not notice anything since he has not driven it with the new motor, get a recomended cam with a chip and it will not let you down, a cam alone is not going to give you 50HP, on a stock motor, Dave
  5. 1990k5fan
    Jul 7, 2006
    217
    Gilroy, CA
    This was going to be for my stock engine. 4x4 got confused because I've been talking with him a lot lately on building a stroker.
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    So what's the deal with this post, it says on the main page that you posted again at 1:32pm today when in fact you haven't posted on here since4/15 at 8:17pm?
  7. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    The poll? I think that counts.
  8. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Awe, that makes sense. I didn't even think about that although i doubt that he voted on his own poll.
  9. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I voted for the Comp cam. because I know it works good with TBI. But looking at the specs for the edlbrock, it is pretty much the same as the comp cam for less money. If Brian recomends it he most likely has a chip burned for it that works well.
    If you have stock TBI heads you really need to change the valve springs to a heaver spring. The stock ones are pretty weak. So figgure on buying a set of springs with the cam.
    Also adding 1.6 to one rockers will help build a little more torque.
    You really need to have headers and performance exhaust to see the maximum gains from either cam.
    If you have stock exhaust and don't plan on upgrading I would go with a smaller RV type TBI cam. Like a Comp 252BH-11. it will build good torque and get good MPG. You wont need chip work with that one either.
  10. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    I ran the whole Edelbrock power package. It all worked together pretty well.
    I should be getting the info on my new motor pretty soon and I will let you know what cam he put in it.
