Which cam to run?
Discussion in 'The Garage' started by BowtieRed, May 19, 2003.
  1. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    Ok, I don't really know a great deal about cams, but I know the higher lift and greater duration the rougher idle and more top end. I run mostly mud, so i'm not looking to bottom end power. I the most power i can get where i can still idle below 2000- even if it stalls out at first and cuts off before it warms up, like eal dragsters. what should i get? thanks,
    red
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    red
    you buildin a dragster mudder? lol lol
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    We need alot more info before we can start to answer that. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/deal.gif
  4. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    Comp Cams 268xe
    Summit part number: CCA-12-242-2
    Mild/rough idle, hella strong mid-range
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    sorry my class ended as i was wrinting that post and i just entered it.
    I'm running a GM goodwrench 250hp 350. i'll be adding some larger headers and 3" pipes within the year and it has a rochchester 670 and an offenhausen dual plane intake manifold. i want this thing to sound like a dragster at top end!! but then of course i'd rather have more power. . . but i was thinking more alond the lines of a 292/296 cam with 510lift, which is the one in jegs that says "rough idle- anything larger will require high compression pistons" or something to that effect.
  6. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Go to Comp Cams website, take an hour and fill out that card. Be honest, and a bit conservative, then buy whatever they tell you.
    We probably won't be able to get enough information from you to 'really' make that call.
    If you don't like Comp Cams, then just do the same with your favorite Grinder.... /forums/images/graemlins/grin.gif /forums/images/graemlins/burb.gif
