which carb works best offroad?
Discussion in 'The Garage' started by short sub, Feb 13, 2005.
  1. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    ive got a 350 with vortec heads, comp 4x4 cam, crane gold roller rockers, edelbrock aluminum intake and currently a 670 holley street avenger. soon im either doing mpi or propane- but ive got a ride coming up this weekend and the carb i have now is horrible. it works great on flat ground but off camber, well its not the greatest. a friend of mine is running an edelbrock 1406 and it seems to be alot better then mine so give me any info please. thanks ryan
  2. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    the consensus is usually a good running quadrajet is best offroad...
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the q jet is probably the best carb for off road, its not called the poormans fuel injection for nothing. the holley truck avenger carb is the next best, then edelbrock.
  4. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    I like my Edelbrock Performer Q-jet. I have been on some steep hills without a spit of sputter.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if anybody tells you anything other than a qjet, ask them who their dealer is, cuz they're gettin some GOOOOOD chit from him!
  6. diesel4me
    Jul 24, 2003
    17,546
    936
    Massachussetts
    dont use theese!
    An Edelbrock performer or Carter AFB carbs arent that great on hills or at angles,or if you get the front end bouncing--I can stall both of my trucks with them just by driving up a pile of plowed snow fairly easy--neither truck did it with the stock Quadrajet,but the edelbrocks do make them more peppy than the stock carb--I only used the edelbrock and carter AFB carbs cause I had them already,and the Q-jet needed an accelerator pump and a gasket kit,so I put them on--
    I liked the performance increase,but was dissapointed with the drivability in cold weather(both ice up too easy,due to the adapter/spacer blocking all the heat)and the hill climbing and tilt problems make plowing frustrating at times,when it conks out at the top of the pile,and floods,and your lucky if it starts again before the battery croaks...:blush: --I've heard their "off road" needle and seat kit doesn't help them much either...
    I'd say the q-jet is the overall winner for mileage,power and driveability(factory knows best!:grin: )--other than EFI,thats the cheapest way to keep it running on uneven terrain...some 2 barrel GM carbs arent bad off road either,dont discount them entirely either,you dont really have to have a 4 bbl carb....:crazy:
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that the Edelbrock carbs are absolutely horrible.
    I have a 100% bone stock non-rebuilt Q-jet on my truck from 1980 that runs better than my brand new Edelbrocks ever did.
    So good, in fact, I've put off my EFI swap for over a year now.:grin:
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    My truck avenger runs a LOT better than the two q-jets I had when the truck is about to tip. It wasn't as hard to tune as a typical holley either, there have been a lot of changes.
  9. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    then you got 2 VERY bad quadrajets, no way a Holley can even compare to a half ass running QJet.
  10. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    I think it depends on the Edelbrock. From what I understand, Edel q-jets are outstanding...
    j
  11. TB2Blazer
    TB2Blazer 1/2 ton status
    Apr 6, 2002
    166
    Cleveland, GA.
    My buddy has an 84 K5 and runs a Q-Jet and I have and 85 and I run a truck avenger and my truck avenger outperforms his Q-jet every time. Off-cambers, descents everything, I dunno if I just got a really good Holley but I am a firm believer in the truck avenger.
  12. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
  13. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    I third the edelbrock perfomer carbs suck off road!
    I run a holly truck advenger and it will run like crazy, the main issue is when I am bouncing around high speed, but that is normal with any carb.
    for simplicity, and cost effectivness I would buy a reman quadrajet, a 400 doller holley does not tute my horn anymore:D
  14. supersize75k5
    Feb 3, 2004
    8,832
    4
    gilbert az
    I think he is talking about the performer series:confused:
  15. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    I am so glad we all get to put our unbiased inputs in....
    I bought the truck avenger and it is good for me to this point... havent really angled the carb yet. I do have a problem from time to time as it runs great but after a while it spudders... i think I have the floats adjusted wrong.... :confused:
    however nothing can beat fuel injection :D
    hopefully I will have a 454tbi this summer and my truck avenger will be going byby.... other than that I will test out my truck avenger more and let yall know...
    but still... my old q-jet was good.. never had to adjust it.. set it and forget it.... the carb ran good... so either way I dont think you will be dissappointed in your choice....
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, you're correct. AFB/Performer style.
    A Q-jet is a Q-jet regardless of brand, all are good.
  17. gjk5
    gjk5 3/4 ton status
    Mar 17, 2004
    5,312
    Grand Junction, CO
    Alright, now I'm a little confused here. Are we taking Rochester QJet against Edelbrock QJet? Because I have both, the Rochester is sitting on a shelf in my garage and the Edelbrock is in the '72, but needs a rebuild bad.
    If someone could clarify for me I would appreciate it, save me some time and effort rebuilding the Edelbrock if you guys are talking about the Edel. Qjet that sucks so bad.
    If so I guess I can just rebuild the Rochester.
    Or it could be that I'm altogether lost here, someone straighten my ass out.
    Just caught that Tim, thanks.
  18. TWISTEDJACK
    TWISTEDJACK 1/2 ton status GMOTM Winner
    Jul 24, 2002
    882
    Boise, ID
    If you want to bolt it on and go then get a q-jet, if you don't mind tuning a little then get the truck avenger. I have had the truck on its nose almost ready to endo and the carb didn't even stumble, I had it on hell's revenge attempting the hot tub (balls bigger than brains) and it didn't stumble with the nose in the air either.
  19. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Seems like a good number of folks try to build a motor and ditch all the smog gear but its difficult to do with emissions testing. Its kind of nice knowing i can put in a performance block and still get great hp with a stock carb and all the smog junk. Only issue ive had with my Qjet is that it tends to load up when I'm wheelin. This sumer I'll be doin a new motor and wil probly toss on another Qjet. Now which brand, I dunno yet.
  20. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    For a standard street holley, I'd agree with you fully. But the Truck Avenger was completely redesigned specifically for an off road application. My Q-Jets worked perfect, except for when the truck was on a severe incline or off camber. Then they'd start to flood, or load up, and just run like crap. This truck avenger has never hesitated one bit in the same situations. I am impressed by the Q-jets in almost all situations, but my new one is definitely a step up off-camber. I wouldn't even touch an edelbrock though.
