which clutch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by atomicdog, Jan 5, 2007.
  1. atomicdog
    atomicdog Registered Member
    Oct 18, 2006
    48
    texas
    converting my blazer to 4 speed already have the 465 and pedals,just wandering wich is best,mechanical,hydraulic,or internal hydraulic.I know some of you guys have done this, any advise?
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    Most guys recommend the hydraulic.
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,994
    130
    The mechanical is much cheaper, easy to find, and more than adequate IMO. If I had the hydraulic stuff in front of me, it would be in my truck. The parts to convert to hydro are somewhat difficult to find and fetch a fair amount of money.
    Run far, far away from internal slave cylinders (though I have never heard of that setup on a SBC anyway)
  4. sweetk30
    Nov 1, 2004
    25,543
    539
    horseheads , ny 14845
    there not that bad. about the time thay let go its time for a clutch job.
    and late 95 up gms are internal style on full size. :D
    what ever you do dont use 3 finger clutch setup with stock hydro parts. or this will happen. pressure plate 1" taller and hits the fork bad. 3/4 release only and sounds like bad starter when running.
  5. fred2mihi
    fred2mihi 1/2 ton status GMOTM Winner
    Nov 26, 2004
    1,272
    Way West in Co.
    I just put a CenterForce Hydralic in my 87. When you put that sucker in gear it is ready to go. I've heard stories of guys getting their mechanical clutch hung up and end up breaking linkage.
    fred2mihi
  6. 1977k5
    May 26, 2003
    9,994
    130
    Tell that to any of the XJ (Cherokee) guys. Their internal slaves fail practically on a yearly basis :eek1:
    **I know that's not what was being discussed, but I know several people that have been through probably a dozen internal slaves combined, and when they go they are a lot more work than an external one**
  7. 1977k5
    May 26, 2003
    9,994
    130
    I would imagine a lot of the breakage on mechanical linkeage is due to the flex between the body and frame (which is amplified by 30 year old body mounts). I had issues with disengaging my clutch when it was flexed out and that was 100% solved by new poly body mounts.
    I have had my clutch linkage seperate on me though. I was gettin' on it pretty hard and the drivetrain torqued itself over enough (2-2 1/2" :eek1:) that the z-bar fell out! Nothing broken and an easy fix, but wouldn't have happened to a hydro clutch. Poly motor/trans mounts will fix that though :D
    BTW, what do you think of the centerforce Fred? I think Scott was asking about my setup (4.56's and a centerforce) before you put yours in.
  8. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    Sent you a PM.
  9. skyyk5
    skyyk5 1/2 ton status
    Jan 2, 2007
    1,537
    N.E. PA
    i just swapped my slush box for a aluminum to 465 best thing i ever did. i used the hydr. out of a 87 3/4 ton. the only problem i had was a master cylinder that only lasted a year. but that was from advanced auto. just look for a 86-87 truck 86-91 1 ton in the junk yard. all got all the parts for $150 bell,pedals lines and all. but they are getting rare. this was the second time i had to find one and it was one truck out of 7 junk yards (it was at the same one i got the first out of) but check ebay
  10. atomicdog
    Oct 18, 2006
    48
    texas
    Still thinkin about it. Thanks
