Which D70?
Discussion in 'The Garage' started by fr8train, Oct 2, 2002.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Ok, looking for a 14FF with 4.56 or 4.88 is like pulling teeth around here. And if you do find one, price is completely outrageous. I found a good stock of D70 rears and they are from early, 70s-80s, Ford trucks. Is there anything that I should be looking for on the diff. tag, aside from ratio? ANY help is greatly appreciated.
  2. nvrenuf
    Jan 7, 2002
    13,073
    245
    Mobile, Al.
    The only ones that I know of that are tricky are the later model Dodges, depending on the year model the spline count can change (nothing bad you just can assume that they are 35 spline because it might be 32 spline), as well as, high ratio axles that wont accept low gears (similar to a Dana 61 problem).
