which dana 60?
Discussion in 'The Garage' started by sf_wood, Oct 25, 2006.
  1. sf_wood
    sf_wood Registered Member
    Apr 4, 2005
    70
    san francisco ,ca
    what trucks did they come in? bolt in?chevy or ford high pinion?
  2. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    91 and before 1 ton 4x4 chevys for the bolt in version, dodge 1 tons have the right side drop too but the spring perch's are different now they use high pinions i think they changed around when chevy went to ifs, ford 1 tons use the driver side drop high pinion
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    D60 from a chevy is a bolt in deal and only found in 77-91 1 ton trucks. I think also a 78-79 ford hi pinion but then you must change t-case to driver drop instead of passenger drop. The dodge is very close only off like 1/2" -1" IIRC.
  4. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Dodge has never used a high pinion D60. Unless you can find a Dodge or Ford 60 for cheap, a Chevy 60 is your best bet. The Ford or Dodge 60's will require other mods which will require $$$. A Chevy 60 will practically bolt in and has the strongest knuckles of the three.
