Which differential
Discussion in 'The Garage' started by AKbigsub, Nov 28, 2005.
  1. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    I have a 10 bolt and a D44 with the hugh hubs. Both are open. The rig is a 90 burb 3/4 ton. Which axle assy would be better? Both have 4.10's.
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    IMO its a toss up, some think the dana has a stronger center section......
    Use the one thats in better shape and keep the other one as a spare. It has been my experience that burbs and 10 bolts don't mix :doah:
  3. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    In the front? It really doesn't matter. Their axles shafts are the same thickness, stubs too. Ring gears are the same size.....really doesn't matter....they are the same strength in reality.
  4. k5redneck
    k5redneck 1/2 ton status
    Jun 24, 2004
    1,000
    mesa AZ
    just use the 10 bolt :D
  5. bornreadyk5
    bornreadyk5 Registered Member
    Aug 5, 2004
    28
    S.E. AZ
    I find the 10 bolt parts easier to find.
    Also, they are much easier to set up.
    They both have pros and cons. But I would choose the 10 bolt because I think they are slightly stronger in the carrier/ring gear area. Other than that, they are dead even in the strength dept.
