which do I use 4 or 6 degree shims
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by fink, May 13, 2002.
  1. fink
    fink Registered Member
    Mar 11, 2001
    86
    With a 4" lift do I use 4 or 6 degree shims. Im using 4 now but have a kinda growl @ 40-60 mph when i let off the gas (kinda drive gear @ float). Have had the th350 & np205 rebuilt w/ new drive shafts (no cv @ rear)???
  2. ZZ4x4
    ZZ4x4 1/2 ton status
    Oct 17, 2001
    542
    Garland, TX
    You really want the u-joints at both ends of the driveshaft to have the same amount of angle to minimize vibration (unless you are using a cv joint at the transfer case). You can use a cheap angle finder from Harbor Feight or Northern and place it on the differential flange by the yoke, and then on the transfer case near its yoke. The two angles should be within a degree or so of each other. This should tell you how much shim you need. Good luck. JT
  3. fink
    Mar 11, 2001
    86
    Thanx JT ill try that
  4. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I got my angle finder in the woodworking section of a regular hardware store (it was a Westlake in my area).
