Which doubler 2" up or not?
Discussion in 'The Garage' started by chvyhs, Jan 20, 2004.
  1. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    Which doubler 2\" up or not?
    Which doubler would you order? The regular one or the 2" up rotation? What are the pros and cons of the 2?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Which doubler 2\" up or not?
    2" up, ground clearance.
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I second...
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Get the 2" up option /forums/images/graemlins/thumb.gif
    I got the 2" rotation and then raised my entire drivetrain 2.75" so that nothing hangs below my frame
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Get the 2", thats what we got for my dad's truck and it raised everything up nice and high. /forums/images/graemlins/thumb.gif
  6. chvyhs
    Feb 12, 2001
    1,469
    So I guess there's no draw backs to getting the 2" up?
  7. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    I think the 2" up is what ORD considers "Regular".....
    The 2" rotation gets things as flat as possible underneath and is such a minor rotation, that it is unlikely to cause any other inteference or clearance problems. My doubler has the 2" rotation, and I think you'll find that probably 90% of the other doubler owners are set up the same way.... /forums/images/graemlins/cool.gif
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    The only draw back I can think of, is it raises the angle of the front drive shaft up a bit higher. Not too big of a deal, since you'll probably invest in some nice shafts anyhow.
    BTW, mine is also 2" up...
  9. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Mine is rotated to where the front output is level with the input.
    I wouldn't recommend it (my extreme clocking) if you want to keep much of the body, but now that Im swapping in a cab I am glad I clocked mine the extra little bit. It would be killer if Watson had time to mock up a K5 with 1" body lift. He could clock up the case till it was just a few hairs from the body. He may have done this already. It just looks like the case sets so much lower in the pics on the main page. My old flat portion of the NP205 is sitting at a 35 degree angle now!
    I did not require raising the engine to get a flat belly pan - nothing wrong with doing so. Frizzlefry has a good idea there, but how much did that raise the CG of your rig? Could you tell a difference?
    If you want to see it, go to my Members Rides page here on ColoradoK5. These guys are prolly sick of seeing my junk. /forums/images/graemlins/thumb.gif
  10. chvyhs
    Feb 12, 2001
    1,469
    I'm not too worried about the body contact. I already have a 2" body lift.
    All this info is exactly what I needed. Thanks /forums/images/graemlins/thumb.gif
  11. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Doesnt the 2" rotation also make it possible to run the front crossmember with no modifications assuming there isnt a lot of suspension lift on the truck?
  12. Boss
    2,550
    Maryland
    Yes, you are correct, no mod necessary on the Xmember with 2" up.
  13. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    ...but how much did that raise the CG of your rig? Could you tell a difference?
    I dont know how much it raised it and I cant tell the differance.I have had my truck past 45* a couple times with out going over so I guess it cant be that bad /forums/images/graemlins/tongue.gif
