Which driveshaft for 14bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Aug 8, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I'm getting ready to install my 14 bolt into my Blazer. It came from a suburban. Is there a driveshaft from some other vehicle with a CV-joint that I can just hunt in the junkyards and have it properly sized?
    Which routes have you guys gone to do this? Ordering a new fancy driveshaft is not an option for me because I'm outside USA /forums/images/icons/frown.gif But there are shops over here that can do the shortening/lenghtening job cheap. Any ideas?
    Thanks.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    When i swapped the 14 into my truck, I just used te stock shaft and the special u-joint.
  3. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    I'm heading out to the junkyard tomarrow to do exactly what your asking about.... I'll post my results, if I don't go brain dead and lose this thread.....
    I whish I knew what steering box I needed .... but thats another thread..
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    When I swapped in my 14 bolt I just had to get the NAPA u joint(#348 or 447).As long as you are not swapping the t- case, then you should be good to just get the special u joint.Mike
