Which Easy-out???
Discussion in 'The Garage' started by walla2k5, Nov 26, 2005.
  1. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Need to extract 2 broken bolts out of my intake manifold. Which easy-out do you guys prefer? The "Spiral" or the "Straight Fluted" extractors? I'm heading to store to buy a set in a day or 2. Thanks in advance...:crazy:
  2. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Mine are Master Mechanic/True Value left h spiral, be persistent, it will come out.:wink1:
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    can you weld a nut to the stub? if so try that as the heat will help in the removale. i have never had good luck with easy outs.
  4. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    I know this sounds stupid but put some bar soap on the EZ out befor you turn it in. For some reason it keeps them from popping and breaking. I have the spiral flute set. I also have a set of those craftsman units that go around a stud to extract it and the soap works on those also. Some old timer from the Navy Yard told me to try this and it works :bow:
  5. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    just snapped a spiral clean inside of a thread, started drilling and tapping. It was an Irwin brand extractor just FYI.
    Jesse
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i prefer the straight fluted style. i have both and use the sprial ones at work. they are nto as good. no matter what you get drill more than you "think" is good. then the soap thing helps as well.
    Grant
  7. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Soap prolly is like the ... whatcha call it, tapping fluid? Which is basically paraffin wax, right?
    -- A
  8. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I've always had better luck with the straight type. The fluted just don't seem to grab as well.
  9. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Try to find the reverse cut drill bits $$??
    Lots of the time when you are drilling them out they will just spin out on their own , no easy out req.
    Just a thought...
  10. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    I find the spiral ones break easier, so I use the straight ones.
    Rene
  11. 81jimmyslt
    Jun 5, 2003
    1,643
    That was another trick the hardware guy mentioned using a left hand bit, they are spendy though.
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Just kidding but maybe it too cold!:D
  13. walla2k5
    Sep 5, 2004
    2,054
    Walla Walla, WA
    Thanks for the tips guys....I'll try the soap trick with lots of PB Blaster,darn aluminum manifolds.The bolts are broke off flush so I went ahead and bought both,just in case.:D
