Which Engine For 89 TBI
Discussion in 'The Garage' started by ZJumper, Dec 13, 2006.
  1. ZJumper
    ZJumper Registered Member
    Sep 20, 2005
    49
    Spokane, WA
    The engine in my 89 TBI Blazer is getting pretty tired and I'm planning on replacing it soon. I don't want to mess around with modding any of the stock TBI stuff as it works fine, but want to get the most out of it.
    So, here is my question...what would be the highest HP GM crate engine the stock TBI would work properly on without any mods to the TBI? Am I correct in assuming the 200HP/300TQ 350cid? Thanks.
  2. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    that should work since it's not a huge jump in power from stock.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Acually TBI in Blazers 350 is rated at 210 hp. If you want the most stock power get the GM crateTBI engine for your Blazer. 12568758 light duty TBI up to 7200 gvw engines have 9.25:1 compression ratio.
    If you get the TBI engine rated for over 8600 GVW they have a lower compression ratio and make less power.
    Diference between the two is the heads and the HD model has 4 bolt mains. Dont need 4 bolt mains in a Blazer unless you plan on building some horse power
  4. 88$PIT
    88$PIT Registered Member
    Sep 12, 2006
    66
    Lincoln CA
    Bear in mind that the engine for the 8600GVW loses HP to the other engine because it is configured to make peak torque at a significantly lower rpm. I had one in a 1 ton rated rig in '89 and even though it wasn't quick it pulled like a gorilla with 4.10 gears.
  5. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Thunder is correct. 12568758 is the stock replacement engine for your K5. That engine comes with 3 year 100,000 mile warranty. Any performance engine from GM will not be a trouble free bolt in & go deal. Nor will it have that warranty. Performance stuff is 12 & 12.
