Which Front Shackle?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Feb 15, 2002.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    What are the pro's / con's for the ORD Front Shackles,and Hill 4 Wheel Extended Front Shackles? Which one's do you run? Thanks for any info in advance [​IMG]
    Eric
    from Freekmont,CA.
    <a target="_blank" href=http://www.community.webshots.com/user/vwryda> Miscellaneous Debris </a>
  2. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    The only con I can think of is on the hills shackle, it pushes the front pinion angle down , but it can be corrected by degree shims. I wanted the extra 1" lift to even out the 5.5"blocks in the rear now that I have lightened the rear by installing a soft top so I bought the hills shackles. They are beefy as heck but not greasable which doesnt bother me too much.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run the ORD HD shackles in front. They are really stout pieces, that I would recommend to anyone. I wasn't looking to raise the front anymore, but I didn't want to be a victim of a broken shackle so ORD's were for me. After I took out the factory shackle I realized how thin the factory's were, and how stout the ORD's are. There is no comparison. I also like the greaseable feature with the ORD shackles. Not to mention that I have had good experiences with Offroad Design before, and I knew there products were top quality.
    My Chevy isn't broken, its just out of gas.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'd personally make your own shackles. I don't understand how ORD can expect to get money for their shackles. Sure, they're nice, thick, and pre-made--but there's nothing really special about them. The kit is just four pieces of steel with hole drilled in each end.
    Tim
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your right, but some people (me) doesn't have access to a drill press and other good stuff like that so I just save myself time and hassle and get it from them. Also I can't put that nice coating, or the cool Offroad Design sticker on either.[​IMG]
  6. TwoCrowsDesign
    TwoCrowsDesign 1/2 ton status
    Jul 13, 2001
    387
    For 88 and up the ORDs are the same length as stock, the hill's are longer by some measure (2"?)
    John
