which gear oil do you use?
Discussion in 'The Garage' started by muddybuddy, Oct 12, 2005.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    hey guys, just got my 10b and 14b regeared and locked, and was wondering what oil you guys trust in ur axles. thanks
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    valvoline 80/90w is what i use with no problems. Im sure you can use pretty much any brand and be fine.
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
  4. blazerpunk
    blazerpunk 1/2 ton status
    Feb 3, 2004
    121
    Trinidad, CO
    I buy cheep stuff and change it frequently.
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    80/90 was what i thought. any special grade?
  6. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    what he said. i get the gallon jugs of coastal 80/90 at autozone.
  7. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Redline Shockproof Heavy Gear Oil. It is a full synthetic. It is kinda pricey but it has worked great for me.
    Harley
  8. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    That is the best stuff you can put in a diff. It has such a high PSI rating its like the teeth dont even come in contact with eachother.
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thanks a bunch, thats what i was looking for. :D might be a lil more money, but to me its worth it.
    where can i get that stuff?
  10. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    that slippery, brownish, very smelly stuff :D
    actually i use what is it,,95/120 or something like that?
    the thicker stuff :p:
  11. skelly1
    skelly1 1/2 ton status
    Sep 2, 2002
    554
    San Diego, CA
    Valvoline, 80W90.
  12. prossett
    prossett 1/2 ton status
    Sep 29, 2005
    165
    United Arab Emirates
    What's the difference between 90 grade and 140 grade gear oil?
    I was once told that 140 is better for older gears...
  13. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    I use 80/90 from wal mart :D
  14. jhellwig
    jhellwig 1/2 ton status
    May 7, 2005
    420
    Bonaparte, Ia
    90 weight is much thiner that 140. 90w at 40 degrees is about what 140 is a 80 degrees. 140 is more or less a greese at freezing. I would avoid using it in anything other than farm equipment or extream summer heat in a diff.
  15. erik59
    erik59 Registered Member
    Jun 4, 2005
    52
    Parkersburg, WV
    I've always used Redline or Amsoil products. I like Amsoils motor oils better than Redline, but in trannys and diffs I always use Redline. Makes a tranny shift like butter is in there. Like they say.....you get what you pay for. My .02.
  16. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    thick is better!
    I like using 85w/140 gear lube in leaky transfer cases and rear ends..it leaks out slower,and all of mine have 100,000 plus miles on them,so there is plenty of clearence for thicker oil..in something that doesn't leak,or a standard transmission,I'd use 80w90 or whatever else the book says too--
    I tried using 85w140 in a SM465 I had that was noisy,along with a can of STP..it was nice and quiet,but when winter came and it got below 30 degrees,I nearly broke the shifter off trying to get it in gear first thing in the morning!..had to put 80w90 back in.. :doah: :crazy:
  17. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    I don't get into any water crossings so I use Mobil full synthetic or Valvoline DuraBlend semi synthetic.
    If you are mudding or 4x4 or towing boats where you are submerging the diff you need to change the fluid often, and if that was the case for me I would just buy the coastal lube by the gallon.
    Tim
  18. gotmud77
    gotmud77 1/2 ton status
    Aug 4, 2003
    689
    bellefonte
    I run the royal purple in everything. Trans,doubler,axles,engine and love it. I would recommend it to anybody. It is a little pricey but worth it.
  19. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Regular parts store 85/140 upfront where its open and hardly used . Redline Shockproof heavy out back with the locker , on Harleys advice . He was right too , you start thinking of dimes and quarters if ya see a drip :D
  20. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Looking at where he's living, 140 might work good.
    I usually run Vavoline 80/90 Durablend. I like using synthetic.
    I may switch to that Red Line stuff though. Sounds like the stuff.
