WHICH GLOW PLUGS
Discussion in '1982-Present GM Diesel' started by josephn, Jun 14, 2001.
  1. josephn
    josephn 1/2 ton status
    Nov 3, 2000
    138
    Utah
    I am replacing my glow plugs (currently ac 11g I think) what are the best to put back in. I have an 82 6.2.
    1982 6.2L Diesel K5 Blazer, TH700, 31 inch tires.
    Fire ALWAYS makes it better.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Manual or automatic glow plug control. If manual AC 60G. If automatic stick with the AC 11G.
  3. josephn
    Nov 3, 2000
    138
    Utah
    IT IS AUTOMATIC.
    IS IT POSSIBLE TO PUT A MANUAL SWITCH IN PLACE OF/ OR IN CONJUNCTION WITH THE AUTO CONTROLER?
  4. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Yes it is. Find your glow plug relay thats on the drivers side under the hood. Find the blue wire. Leave it hooked up. Take a jumper and place it in the blue wire terminal. Now turn the key on..don't start it...and ground that wire. You should hear the glow plugs cycle. Now go to Wal Mart or your parts store and get a simple momentary switch (horn button works good). Hook it up. You have a manual switch.
    SK-15
    J**P...it's whats for dinner!
    Roads? Where we're going, we don't need any roads!
    <A target="_blank" HREF=http://SK-15.coloradok5.com>http://SK-15.coloradok5.com</A>
    William Imhoff likes this.
  5. josephn
    Nov 3, 2000
    138
    Utah
    if i put a manual switch in with the auto controler how long should i hold the cycle? Also if i do this should i use the ac 60g instead of my ac 11g glow plugs?
  6. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Depends on your rig. I started at 20 sec in winter and got it down to about 10. Summer is no problem...about 7 seconds. You just have to play with it and find your sweet spot. If you go manual go with the 60s.
    SK-15
  7. josephn
    Nov 3, 2000
    138
    Utah
    Cool thanks alot i am going to make me a manual switch.
