Which headers?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Truckfan2, Apr 4, 2001.
  1. Truckfan2
    Truckfan2 1/2 ton status
    Apr 10, 2000
    343
    Northern IL
    Right now I have Hedman headers and they hit my front shackles... I have 6" Tuff country springs and ORD HD shackles w/greasable bushings. Anyone know what header will fit with out hitting? I was thinking of Thorleys... any ideas? Thanks, Pete
    Have been stuck (once) as of 8/12/00
  2. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Truckfan,
    I have Thorley headers and they hit the shackle too. I don't know what gives with these header companies. If they would just make them a little shorter, everything would be fine. I have gotten comments from several people who attached a come-along to the header and opposite frame rail. They pulled the header until it cleared. I did it too and got enough clearance to drive. Will probably have muffler shop bend or cut header collector and reweld. Good luck. jt
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I've got headman headers and they clear just fine. Are you sure you got the ones for 4x4? They almost look like shortys.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  4. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    I looked into it and edelbrock seems to be o.k. and also thorley and one more...flow tech...yep.
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  5. Truckfan2
    Apr 10, 2000
    343
    Northern IL
    What do you mean by ok? they're supposed to clear the shackle bolt? well, out of thorley, edlebrock and flow tech, which one lasts longest and would fit a vortec head?
  6. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    My Thorleys fit just fine. Thorleys are quality pieces, am happy with mine.
  7. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    ive got the same problem.im gonna turn the bolt around threads out.get your headers jet hot coated ive seen them they look killer,and supposed to help w/rust cuz they do inside and out.next set i get will be coated by jethot.
    PURE INSANITY
    86 blazer silverado 400 horse 350 w/vortec heads 38 x15.5 swampers (40 hawgs next)10 bolts(blah)w/4:88s coming soon,14 bolt.
