Which Holley carb is this? (need to rebuild)
Discussion in 'The Garage' started by 89GMCSuburban, May 3, 2003.
  1. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    My friend just gave me a Holley carb that needs a rebuild, but I do not know what model number it is, or for that matter, where to look if it's on the carb...so....
    It's a Holley spreadbore
    standard finish
    Manual choke
    Vacuum secondaries
    single accelerator pump
    What is this? I tried looking on the Holley site, but could not find what it was... thanks in advance, guys!
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    look on the choke horn..should be some numbers....if ya tell me the numbers ill tell ya what it is /forums/images/graemlins/thumb.gif
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    look at the front face of the choke horn. It will say something like "list 1850-1" or something similar. Usually a 4 or 5 digit with maybe a dash 1 or a dash 2 after the main #. I have some holley books. I'll check #'s also
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
  5. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    It says LIST 8700 and below that is 1079...
    I guess that means it's an 8700....I don't even see these on the website
  6. leadfoot067
    May 14, 2001
    1,563
    its a 650 spread bore vacume secondary..q-jet replacement carb...shoule work well for ya /forums/images/graemlins/thumb.gif
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    it is listed here
    list 0-8700
    model 4175
    cfm 650
    rebuild kit 37-1537
    trick kit 37-933
    primary and sec needle and seat (16,17)
    pri main jet 122-582
    sec jet or plate 134-21
    pri metering block N/S
    sec metering block 134-21
    pri power valve 125-85
    pri discharge nossle .025
  8. 89GMCSuburban
    Nov 15, 2001
    3,005
    Thornton, CO
    Thanks guys! /forums/images/graemlins/thumb.gif It's going on my 1967 C10 in place of a Quadrajet that's seen better days...let you know how it does!
