Which is better silicone or a gasket or both??
Discussion in 'The Garage' started by barneybasher1010, Apr 3, 2007.
  1. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    On my 14ff the axle flange gasket is leaking, what would be better a new gasket or silicone or both?
  2. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    i use silicone rtv and it works awesome. you basically have to clean the heck out of it though, to make sure your getting good adhesion. brake parts cleaner and a sock works very well to clean the surfaces.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I only run RTV and have had zero issues. Make sure you let the RTV skim over before you put it together it will seal better.
    You will find about a 50/50 mix of people that run the gaskets or RTV it is kinda a personal preference.
    Ira
  4. AKbigsub
    AKbigsub 1/2 ton status Premium Member
    Sep 9, 2005
    1,549
    17
    Anchorage, AK
    The Right Stuff. The only gasket material I use on non-pressure or high-heat sealing surfaces.
  5. dasanii19
    dasanii19 1/2 ton status
    Oct 11, 2006
    344
    NV
    I run gaskets with black RTV hi temp on both sides and it always keeps a nice seal.
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I use gaskets. Kinda like Chevy did.
  7. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    I went with some red? rtv. It sealed it anyway.
  8. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    i pretty much use only gaskets on my dd, and mostly silicone on the k5. gaskets are good when the clearances are consistent and no damage is present, but the silicone allows you to adjust for minor imperfections on the mating surfaces.
    speaking of mating, i'm actually not a fan of silicone on chicks, and a gasket would be really strange in that application. :wink1:
  9. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    You're right, when it comes to ladies, it's all about the liquid latex... :D
    I used just the gasket last time... sealed just fine.
  10. barneybasher1010
    Sep 25, 2005
    908
    PORTERVILLE CA
    I had to "order" new gaskets from Kragens. Auto Zone said they don't have such a thing (dumb asses). I even had the part number(fel-pro 55350). I will put them on and if it leaks anymore I will silicone it too.
    THANKS EVERYONE:bow:
  11. dasanii19
    Oct 11, 2006
    344
    NV
    Yea I dont put huge blobs of that RTV on the gaskets , I run a bead then wipe it flat with my finger
  12. Randy92782
    Randy92782 1 ton status
    Mar 25, 2007
    16,287
    Arcadia, MO
    if i have silicone i silicone it. if i have a gasket i use it and silicone. not sure it makes a difference though. i have almost every color but like red myself. seen people use household silicones for a quick fix. not recommended
  13. greyhoundjc
    greyhoundjc 1/2 ton status
    Jan 23, 2005
    127
    Georgia
    I used just the gasket, but I can't see where rtv would hurt.
