Which is it, Dana 44 or GM 10 Bolt?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by fbronson, May 21, 2004.
  1. fbronson
    fbronson 1/2 ton status
    Jan 12, 2004
    104
    Denver, CO
    A little while ago, I bought a pair of axles. The guy advertised them as a 14bff rear and a dana 44 front 3/4 ton axles. I got them in the mail, and they sat in the garage for a little while. When I unwrapped them to start the rebuild, I noticed that the front axle looks remarkably like the current 10 bolt on the front of my truck right now. It has 8 lug hubs, and the tie rod looks a little different than what I've got. The saddest part of the whole deal is that the passenger side steering knuckle is not a flat top, which means that I'll have to get a different steering knuckle if I want to do the cross-over steering. /forums/images/graemlins/angryfire.gif The diff housing has those same little bumps on the lower flange as my 10 bolt, so I am a little unsure. So what is it?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    <font color="black"> Dana 44 </font>
    <font color="black"> 10 bolt </font>
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    sounds like a 10b with those two little ears. Same axle as a D44 anyway. Unless these were pre 76-77 axles the dana 44 wouldnt have had flat tops anyway. Did ya make sure that the gearing mtches in them? /forums/images/graemlins/whistling.gif
  4. fbronson
    Jan 12, 2004
    104
    Denver, CO
    So post 76-77 the dana 44's didn't have a flat top kunckle? That was the most important thing to me, actually. I knew that the diameter of the axle shaft was the same in both the 10b and the d44. Although, I think the d44 has a slightly thicker axle tube wall, doesn't it? Yeah, the gears are 4.10's in both. /forums/images/graemlins/thumb.gif So that is good anyhow.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    77 and earlier had the flat tops, 78 and newer 44's didn't.
  6. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    D44's housings are made of nodular iron and 10B housings are made of grey iron. The D44 housing is slightly stronger but only really matters if you are getting a lot of air. I wouldn't be mad, they are basically the same thing. Not only that but now you don't have to buy different brake lines and if you ever find a D60 it will swap right in because it shares the same lines as a 10B. /forums/images/graemlins/cool.gif
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    By the way the 10 bolts in here is a rear, the front is a little different in shape, looks more like a 12 bolt shape but has the fill hole in the cover.
    I don't have a pic of one now but I have a few sitting in my driveway.
  8. fbronson
    Jan 12, 2004
    104
    Denver, CO
    Yeah, I am pretty sure that what I have is a 10 bolt. The interesting thing is that someone did an 8-lug conversion on it, and in doing so they must have put brake calipers from a Dana 44 on it, because I did have to swap the brake lines. Thanks for the info on the types of iron used. /forums/images/graemlins/waytogo.gif I am not really planning on "getting air" in this truck, so I guess I should be o.k. /forums/images/graemlins/thumb.gif
  9. JDBlazer454
    JDBlazer454 1/2 ton status
    Feb 27, 2002
    951
    Vancouver, Wa
    I had an '82 Suburban K20 (years past) that had an 8 lug 10 bolt stock, I thought hmmmm now that is strange but the old guy I got it from I know had never touched it. So from my experience they are out there.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Many rigs had factory 8 lug 10 bolt fronts. I ran one for years in my rig until I swapped in the Dana 60.
  11. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    All GM K series trucks started getting 10B fronts instead of D44's under the 3/4tons in 79', 8 lug of course. IIRC. My 8 lug 10B came from a 79' 3/4 burb.
  12. fbronson
    Jan 12, 2004
    104
    Denver, CO
    Nice pic! Have you ever had any problems running 35's on a 10bolt? So did those 8-lug 10bolts come stock with 4.10's? I know that the 14bolts often came stock with the 4.10's in the 1 ton trucks.
  13. JDBlazer454
    Feb 27, 2002
    951
    Vancouver, Wa
    Pretty normal for 4.10's with 8 lug no matter what the front end is. Mine was 4.10 and just about every 8 lug front end I have ran across has been 4.10. I ran 35" Gumbo mudders (cheap available tire at the time) with no problems but it was mainly a tow rig and only saw offroad once.
  14. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    To this day most 3/4-1ton trucks roll off the line with 4.10's. 4.10's have been standard since the 60's or 70's with 3.73 and 4.56 being options.
    I have never broken anything on my front 10B. I was lucky and and picked my current front axle up because it looked like it had been in 4wd about twice! It was probably a grocery getter burb(donor veh.) it was totally cherry and that is probably why I have never broken anything. As you can see I am running 35x16 boggers and they are probably the nastiest 35 out there as far as breakage. /forums/images/graemlins/thinking.gif I used to wheel a lot in the mud and have pulled on asphalt a few times burning rubber without breakage. Maybe I'm lucky. /forums/images/graemlins/dunno.gif
  15. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    There are alot of 3.42s as well. Esp in the '88-98 3/4 tons. At least thats whats in the junkyards around here.
  16. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Kind of the Grayist of Gray Areas there. I bought a 77 burb with and 8 lug 10 bolt. D44 and 10 fronts and 10 and 12 bolt rears were both used it seams from 77 unitl they ran out of 44's and 12 bolt.
  17. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    My 90 V2500 /forums/images/graemlins/burb.gif came stock with 3.42's 10b front &amp; sf14 rear.
  18. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    3.42's and even a 3.20 something were also options but are rare for the most part. /forums/images/graemlins/whistling.gif
  19. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    They say 2.73s were rare in K5s too. Yet I managed to buy one of them as well. I have NO luck /forums/images/graemlins/crazy.gif
  20. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Yeah, it's crazy what they put in the 1/2 tons, 3.08's and 2.73's are a joke...
