Which is stronger SM465 or TH400/475
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Batmanjr, Jul 29, 2001.
  1. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Which one is stronger a SM 465 or a TH 400/475. I'm trying to get an idea of what is going to hold up best in the long run.
  2. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    The TH400 or 475 is a very strong tranny...but I'd still say the SM 465 will take more abuse for longer and still live.
    Rene
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I agree, can't beat a manual for strength.
    Tim
  4. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    the turbo 475 is one hell of a strong tranny since it has straight cut planets, but the sm 465 is almost bulletproof. If you were to tear one down and look at the diameter of the gears inside, I think you would be impressed. I have only seen 2 sm465s break. i have seen countless 400s go south, as well as more then a few 475 destroyed in motorhomes.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  5. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    What about the SM420?? Where do they fit in?
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  6. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    SM465 kicks arse! But the TH400/475 are the strongest GM automatics before the 4L80, I think.
    The guy I sold my old truck to somehow blew the 465 shortly after I sold it to him... Don't ask me how, it was rock solid when he drove it away...
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **K5 - What more is there to life?**
  7. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    The SM465 is what replaced the SM420 in the late 60's(I think it was late 60's) The 420 had been around forever before that. They are almost the same, but the 420 has a lower first gear by just a little bit. 7.02 or something vs. the 6.55. I also heard its more "rough around the edges"...meaning it makes more noise and it shifts more like you're driving a tractor than a truck.
    '73 K5
    Chevy good...Ford bad
  8. '73 K5
    1,763
    Kansas
    Have to say the SM465. When I bought my Blazer I changed out all the fluids. There was mud and water and a little gear lube mixed in my 465. And I'd driven it like that for a while. I put new gear lube in it and its been problem free for the last 4 years. Try the mud and water thing with an auto, and you're going to be spending some serious cash.
    '73 K5
  9. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    Just to play devil's advocate here; remember the weakest part of the SM465 is the clutch. A poor driver/technique will smoke a manual (clutch) in short order. On top of all that the U.S. military gave up on manual trans years ago (although M35s still soldier on w/a stick). Maintenance required was the issue (plus the cost to train operators how to drive a manual). Every HMMWV has a TH400 or the new 4L80E.
    That all being said, I'll still be plopping a 465 in my Jimmy soon.
    Dan W.
    Real trucks don't have spark plugs!
  10. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    they're both very strong obviously.. but the 465 wins in the longevity department.. there are many untouched 465s still running around after 25+ years.. dont know of any autos, and if there are, they're on their last leg..
    mike
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    HMMWVs should not be the standard to judge how strong a tranny is. They've got gutless motors and never tow anyway.
    If you've got a good aftermarket clutch it'll take any beating you can put to it. Don't believe me? Go to the dragstrip sometime.
    Tim
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    without a doubt the sm465[​IMG]
    77blazer see it at<a target="_blank" href=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</a>
  13. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    DieselDan is right. The clutch with the sm465 is definitely the weak point. Smoke your clutch and the tranny might still be good but your truck isnt going anywhere FAST. You'll be crawling home in 2nd or 3rd gear. The tranny itself is strong as an OX, just all I'm saying is the clutch is where all your attention will be. With the auto its the same thing, the internal clutches will wear out after a while and require a rebuild of the tranny to fix that. I just swapped in a SM465 from a th350. So I've been on both sides of the barrel here. Just my 2 cents
    Crawlin the rocks with my K5
    <a target="_blank" href=http://www.rockreadyk5.com>http://www.rockreadyk5.com</a>
  14. Thumper
    1,582
    Alberta Canada
    So the 465 is a 4 spd? or 5?
    Mike
    85 Fullsize Jimmy
  15. thatK30guy
    Jan 12, 2001
    32,076
    55
    465 is the 4 speed manual tranny. The best there is, the best there was, and the best there ever will be!!! [​IMG]
    <font color=blue>Daddy told me while learning to pee......"if you shake it more than twice, then you are playing with it!!!"</font color=blue>
  16. Batmanjr
    Mar 23, 2001
    1,537
    Well you were right Wes, The opinion of the site still backs you 100%. I sure do appreciate all your help and everyone else's poiints here.
  17. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Wes, I disagree. I WANT AN NV 4500!!
    Tim
  18. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I think it's sixes- same same same. They are all tuff trannys.
    Ofcourse, autos are going to wear internaly, but a manuals going to wear out the clutch in about the same amount of time.
    Overall rated power input rating in order I'd say it is as follows;
    N/P 465. N/P 4500. T475. T400. 4L80
    But in reality; It comes down to a matter of prefreance. My current beater/daily driver is a 465- I hate it! My project blazer had a T350 in it and I loved it (but also went threw 2 of them, before it went under the knife. The O/E trans cracked due to loose front motor mount. The second one was a crappy rebuilt unit, The third one I rebuilt with some help and have had no problems with when it was a driver)
    I think as far as wheeling goes, I'd chose the auto over a manual trans.
    Twiztid
  19. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Brian's 60s
    Not to start an arguement, but...
    There are thousands more autos on the road than there are manuals. So figureing that in- there are going to be way more autos being serviced than manuals. It's all relitive.
    Twiztid
  20. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    What do you want to drive? I gave up trying to talk anyone into either trans, it won't work. I really prefer an auto, but a manual works great when set up right too. So if you want a strong auto, use a 475, if you want a strong manual, use a 465. That's all there is to it. Comparing apples to oranges won't work. A lot of it depends on how the truck's set up and driven.
    Just to feed the fire......
    How many 32 spline TH400 outputs has anyone seen worn out compared to the 10 spline drivesleeve that needs to be replace every 80-100K miles in a 465? What happens when it breaks or strips?
    You want to go deeper, how about the "hard on drivetrain parts" factor? Is it better to have "the strongest transmission" and waste axle parts when a "weaker" trans will save the rest of the drivetrain?
    drive what you like.....
    and if you rock crawl, get an auto and learn to like it!
    Making the world better, one truck at a time.
    SW-ORD
