which is the best overall tc
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aduff85k5, Jan 11, 2005.
  1. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    i've got a np 208 at this time was wondering if the best one is the np 205. (for my year truck (85)).
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It all depends on what your setup is and how you drive your rig offroad. I run an NP208 in my K5. The lowrange is better then a NP205's but my tcase is not as strong. I have a mild 350 motor with TPI fuel injecton, 4.56 gears, lockers, 35" MTR's, and I rock crawl it. I have only broken my NP208 once and that was my fault, not the tcase's.
    What is your setup and how do you drive? I say in most every case run it till you break it. I like my 208 and won't waste the time or money to upgrade to an NP205. It will hurt my crawl ratio that I need for rock crawling, and it will cause my tranny life to suffer more then it already does which I can't afford.
    Harley
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I like my 208 but I would like to get a 241 just for the fact that they have a better oiling system than a 208 and you can get SYE kits for them easy.
  4. aduff85k5
    Dec 31, 2004
    91
    florida panhandle
    yea i was just wanted to know. right now the truck dosent go anywhere as it is awating the front drive axle to be regeared. but i live in fl and we dont see too much in the way of rocks here. is there supposed to be a little or a lot of fluid that comes out of the tc when the slip yoke is taken out? what kind of fluid do i put back in and where is the port to replace the fluid???
  5. aduff85k5
    Dec 31, 2004
    91
    florida panhandle
    what is an sye
  6. aduff85k5
    Dec 31, 2004
    91
    florida panhandle
    may be a slip yoke extension? ohhhh or is it a slip yoke elimination, and can't i get a sye for a 208?
  7. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    slip yoke eliminator. None exist for the 208. You can use a non slip yoke part from a dodge case but they are not common. 241 is the best if you aren't gonna beat the living crap out of the rig. If you are then in my opinion a doubler or atlas. Get the strength of a 205 with good low range with the doubler(what I'm doing).
  8. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    I'll vote 205, a simple and durable design.
  9. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I second that ,the 205 is the only part I've never broke in all the years...:D
  10. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    Had a 208 in my 81. When I dropped my rear driveshaft I lost the fluid in the xfer case due to the slip yoke... So now I preffer non slip yokes. But the 208 is decent if you can't see yourself putting a doubler 205/203 combo together. that's bullet proof and by FAR outcrawls a 208. just my $0.02 worth
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I am running a 208, the 241 will bolt right in place correct? are there 241s without the electronic speedo? I would eventually like a 241 with SYE and was just wondering. A doubler would be cool but I wont have any larger tires then 35s and thats alot of weight when I will have plenty of power to spin my tires over in Hi anyway.
  12. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    241 will bolt up in almost all ways. Same pattern at the adapter, same driveshaft setup. Breathers are usually a little different. Biggest thing is that the shifter setup is different. Best bet is to take the shifter arm from the 241 and just replace the 208 one. If thats not an option, you can cut and rotate the end of the shifter arm. The 208 and 241 are about 90* different when it comes to the shifter arm moutning slot.
  13. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    Yes but im more worried about my Speedo, are their non electronic speedo 241s?
  14. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    :shame:
    I seem to do ok with my 208. I run with 4 guys with doublers and I can crawl just as well as any of them can. They may have stronger cases and more gear splitting options, but when it comes to flat out crawl I can hang just fine with there doublers. It would be nice to have a doubler but I don't have an extra $2000+ laying around. :waytogo:
  15. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    Find one out of a 89 blazer or burb. They switched to the electronic speedo in 90
  16. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I'm very happy with my 241, but I definitely want a SYE for it, eventually. For a guy who isn't planing on running the Rubicon or climbing a cliff in 4lo, the 241 is a great TC. The 2.72 low range beats the 203, 205 and 208. I have heard a lot of guys bash the 241 because it wont take a whack from a rock too well. One word: skid plate.
    Just my .02
  17. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Yeah, there are mechanical speedo drive 241's to be had. I had one in my '95 Dodge.
  18. nomadman
    nomadman 1/2 ton status
    Oct 6, 2004
    168
    Enfield, Ct
    Who sells the SYE for a 241?
  19. nomadman
    Oct 6, 2004
    168
    Enfield, Ct
