Which K&N will fit?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Jun 8, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    I'm gonna ditch the air cleaner box on my 84 and go to an open element. Anyone know what open element K&N will fit? It's a debate between the 9 /16th raised element, or the flat offset base for HEI. I'd figure the raised one would clear fine, right? I'm just confused if I NEED to have the flat based one in order for it to fit my truck, since I have HEI.
    <A target="_blank" HREF=http://billybob.coloradok5.com>http://billybob.coloradok5.com</A>
    Billybob, the REAL <font color=red>Bionic Redneck</font color=red>
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    I'm running a 14x4" open element. Mines a carborated motor ('79 model).
    <font color=red>I'm a psychic amnesiac. I know in advance what I'm going to forget. </font color=red>
  3. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    It's not the flat part that makes it clear the HEI. It's the offset hole for the carb that makes it clear the HEI. It pushes the breather forward to clear the distributor.
    -BuSH
    I'm a dislectic agnostic. I believe in a higher being, his name is DOG. [​IMG]
  4. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    What kind of shape is your airbox in. My cousing just bought an old K5 and needs a descent airbox, I may be willing to buy it off ya to offset the cost of the K&N.
    If you didn't built it yourself, how can you call it yours.......?
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It depends on where your coil is mounted. If you have the HEI setup with the coil in the top of the distributor cap, then you need the offset housing. If you have the HEI setup with the coil mounted on the intake manifold, then the other one should fit. I'm not sure what year they changed from the integral coil to the standalone coil.
  6. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    I haven't really taken a good look at the airbox. I haven't seen any really bad dings or anything off of it. It's ready for AIR, so it has a hole in the snorkel to accept a heat riser, or whatever the heck comes from the manifold to the snorkel. I'm getting the truck back today (hopefully). I'll fill you in on the condition later.
  7. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    I myself have'nt seen an off set base, but i have seen a raised base and the low profile ones. what i'm getting at is
    why couldnt you go up with air cleaner. I have an 83 but that
    wont help you i have a Mallory ign. not an HEI.
    Lost? i'm not lost i'm just disorienated
  8. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    I was able to fit a 5" tall K&N with no offset. They called it the dropbase version in summit catalog, but it was barely dropbased. I compared it to a friend's dropbase and his really has the base dropped. I have the HEI dist. with integrated coil. It cleared it fine. The only problem is that the wingnut has to be tightened well, or it will (barely) scratch the hood.
    Good luck
    <font color=purple>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  9. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    I was looking in the summit catalog, and they have gauze/oiled reusable open elements for about 3/4 the cost of a K&N version. Anyone heard anything about these?
  10. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have a flat bottom non-offset on mine. It fits fine w/ HEI. I don't know why you would need the offset.
    '71 Blazer CST with alot of rust
