Which line in IN for a trany cooler?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87superblaze, Feb 25, 2002.
  1. 87superblaze
    87superblaze 1/2 ton status
    Mar 12, 2001
    104
    Upper Michigan
    I am installing a transmission cooler for my 700R4. What line is the return line to the trany? Is it the top or bottom line on the radiator?
    Your help is much appreciated!! Otherwise I have to do it the hard way. This will really save me time. BTW, 1987 TBI 350.
    Nick
    My Truck <a target="_blank" href=http://www.community.webshots.com/user/nicksm79>http://www.community.webshots.com/user/nicksm79</a>
  2. Stomp
    Stomp 1/2 ton status
    Feb 23, 2002
    168
    Hill Air Force Base Utah
    99.8% sure the top is the "in" line and the bottom is the return
    <a target="_blank" href=http://www.geocities.com/custar/index.html>Your parents WANT you click here, NOW!!</a>
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    top it is,
    Grant
    take me drunk, i am home
    www.geocities.com/seventy4blazer/parts4sale.html
  4. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    does it matter?
    wont the cooler work no matter where you install it in the line?
    i am not being smart, i just bought a cooler today from napa, and was planning an install in the next few days, and did not think it mattered
    chris
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  5. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    Yes, it really does matter. If the ATF goes throught the cooler first and then throught the radiator, it will defeat the porpose of having a cooler. If you think about it, the ATF will cool down going throught the cooler but will heat up when it goes throught the radiator. The reason for the cooler is because the radiator is still too hot for ATF.
    The most effective way to use a cooler is to have the ATF go throught the cooler last. Right before it goes to the transmission.
    BTW, thanks everyone for replying so fast.
    My Truck &lt;a target="_blank" href=http://www.community.webshots.com/user/nicksm79&gt;http://www.community.webshots.com/user/nicksm79&lt;/a&gt;<P ID="edit"><FONT class="small">Edited by 87superblaze on 02/25/02 10:02 PM.</FONT></P>
  6. Seventy4Blazer
    Apr 21, 2001
    5,634
    Escondido, CA
    it is just better to put it on the low pressure side, less leaks to worry about. using hose clamps is ok, but after time they tend to wear out the rubber. using the low presure side makes it so you can use larger tubes also(it helps drop the presure).
    Grant
  7. RESTORE89
    Jan 31, 2001
    548
    CHAS SC
    so then i should install it inthe bottom line?
    what's in it now?
  8. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    your bottom line should run into the radiator, then out of the radiator to your new aux cooler, out the aux cooler to the top line in your tranny.
  9. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    Why not just use the cooler and bypass the radiator?
    1984 GMC Jimmy 379 diesel, 700R4, 3.73s, 31x10.50 x 15
  10. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    I am not sure about that one. I thought about it a few times but don't have the nads or the money to try it. It sounds like it would work but I don't want to be the one to fry my new trany!!
    If this works, let me know LOL!!!
  11. 87superblaze
    Mar 12, 2001
    104
    Upper Michigan
    Here is a primative diagram on how to hook up your trans. cooler.
    Click on my webshots Link below and look for Trans. Cooler Diagram.
    Thank You and Your Welcome! :)
  12. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have always installed my Trans coolers with the tranny fluid going thru the aftermarket cooler first then thru the radiator then back to the trans. I have never had a problem running them that way.. Most instructions recomend they be installed that way. Because the water around the stock tranny cooler has already passed thru the cooling coils its pretty cool on that side of the radiator anyhow.(unless your radiator is bad or plugged up)
    It really doesn't matter much which way they are installed in warmer climates.
    But in colder weather, running it thru the radiator helps keep the fluid in its best operating range ( around 150-160).
    Running too cold of fluid thru yur auto tranny can damage it also.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
