which one's where?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NoSmog73, Feb 28, 2002.
  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    which one\'s where?
    Ok I asked this before but can't remember sh!t... Ok which wires go on the *of the coil and which ones on the - side of the coil for a 73 350 the wires are black condensor wire,#2 brown wire from loom..#3 wire from dist. Thanks again..mike
  2. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    Re: which one\'s where?
    ttt
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    The wire from the distributor goes to the NEG post.
    The other 2 go to the POS post.
    One will be from the R post on the starter solinoid, which gives the coil full battery voltage on start up.
    The other will have a ballast type resistor on it giving the coil around 6 volts while the engine is running.
    the resistor has to be there because full battery voltage all the time will burn up the points.
    I did not think that any one had points on a rig any more.
    An HEI unit will drop right in and is only about $30 at a salvage yard.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    soon no more but for now I got them -thanks for the info,all the ones at my pick n pull have always been thrashed I keep looking and soon I will be rewarded...
