Which paint for leaf spring?
Discussion in 'The Garage' started by Emmettology 101, Apr 4, 2005.
  1. Emmettology 101
    May 9, 2000
    8,126
    FL
    Do you guys use normal rattle can primer and paint for leaf springs? Or is there a paint out there desinged to work with the flex?
    :D
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Winterizing Undercoat paint works wonders on flexy parts... my whole undercarriage is covered in it, and has yet to crack..
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    There is a rattle can paint that has teflon in it. My brother used it on his springs and I believe it made a difference. As far as longevity of it I couldn't say. His truck was never completed. :frown1:
  4. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    I used an epoxy enamel of my 57" Ford springs 3 years ago. They have been flexed into reverse arch more times than I can count and the paint hasn't chipped or flaked at all. It's tough as nails, and smooth enough that the springs don't bind against each other.
    Rene
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    Thanks all!
    Rene - did you clean the springs to bare metal? And did you use a primer or just the paint? :D Thanks.
  6. JK5
    Jan 31, 2002
    3,453
    Norton, Oh
    Krylon Rust Tough...
    LOL....You're not building a show rig or are you??? ;)
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    Yep! ;)
    Just figured while i had them off, I'd clean them up some. :D
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Like Kert said, look for the paint with Teflon in it. I'm gonna tear down my 52s, sandblast them then coat them with that stuff.
  9. diesel4me
    Jul 24, 2003
    17,561
    942
    Massachussetts
    Por-15??
    I never tried it on springs except for coil springs ,but POR-15 would probably work good on leaf springs too--but you would be wise to topcoat it with another paint,it has no UV resistance and fades to flat black under sunlight..
    Other than that,maybe some kind of polyurethane enamel like Dupont Imron would work--I see fleets of cement mixer trucks painted 10+ years ago with that stuff,and steam cleaned every week that still look like new!.. :crazy:
  10. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'm having good luck with Rustoleum "Hammered" paint so far. It seems to be pretty durable compared to regular Rustoleum and Krylon. It's about $4.50/can though. I haven't checked yet but I'm pretty sure it held up to brake fluid... I know the Krylon stuff I used just melted off and it had a couple weeks longer curing time.
    I wirewheeled my leaves, cleaned them with brake cleaner, then put the "hammered" paint on them.
  11. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    graphite-impregnated rattle can paint was recommended in one of the primedia mags recently. I just use the cheapest rattle-can primer and paint I have laying around. I use UHMW-PE sheets between my leafs... less friction than any paint will ever give ya. More durable too.
    j
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    I am using the Hammered Rustoleum on the frame. Wish it was a little blacker... Maybe I'll use it on the springs too.. HAd it on my rockstomper Rock rod and it held up great....
    Will be using teflon pads in between my leafs. :thumb:
  13. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    teflon isn't the best material for this application... thats why the factory teflon pads are usually trashed and people replace them. UHMW-PE has waaay better impact/abrasion resistance. I completely cover the entire length of the leaf with it, thats why I don't care about $pendy paint to reduce bind. ;) more on this junk and its tech specs coming up in my mother-of-all 52" spring swap writeup...
    j
  14. Emmettology 101
    May 9, 2000
    8,126
    FL
    Hmmm... UHMW-PE would be cheaper too. What thickness are you using?
  15. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Try this
    I used POR 15 on mine so they would look purdy and 2 years later it is still on.
  16. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    would por-15 or eastwood rust ecalapsor rub off though?
  17. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    0.030"-0.060". I get the tape and just remove the sticky stuff.
    j
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I think 3M VHB tape would hold onto PE, stuff is hard to remove from anything else. Heck, million dollar RV sides are bonded on with it only. McMaster has it.
    The graphite and moly containing paints have been a disappointment to me. They don't inhibit rust and they don't seem to stay on very long either.
    MISF used POR-15 on his leaf springs. Great for rust, mediocre for friction.
    I wouldn't advise sandblasting leaves. Sand has sharp edges so it's the reverse of shotpeening which is not a good thing. Use a stripper instead. Two if you can get 'em w/o the tassels. Er, wait.......
  19. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    Im not a media-blasting guru, but there are less abrasive medias other than sand that you can get/use right? I agree that anything that is gonna weaken the material in the spring wouldn't be a great idea...
    j
  20. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    334
    Fort McMurray, Alberta
    I plan to blast mine. Can't possibly leave a worse surface than the rust has...
